What have you done to your c today?
Discussion in 'Prius c Accessories and Modifications' started by kingnba6, Nov 21, 2013.
  1. edspecR
    edspecR Member
    136
    94
    Berkeley
    i figure it should just pop off with some clips no?
  2. edspecR
    edspecR Member
    136
    94
    Berkeley
    cyeremian likes this.
  3. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    Sort of. You have to pop the center off and the cup holders and then its just clipped in .
    #1103 Squeakasaur, Apr 14, 2017
  4. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    got bored of the white led lights so switched to blue. Also spiced up my shift plate
    edspecR likes this.
  5. djdawn
    djdawn Active Member
    255
    116
    Escondido, CA
    2014 Prius c
    I'm not a fan of the rear wiper either. It's something I never use and think it's actually in the way. What did you use to patch up the hole?
  6. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Just finished installing LED footwell lights connected to the dome light. This allows the lights to come on when the door is opened and fade to off when the door is closed and are operated by the dome light switches.
    J Buck, Squeakasaur and djdawn like this.
  7. edspecR
    edspecR Member
    136
    94
    Berkeley
    same. as much as others on here try to say that its like the most necessary thing on your rear end, it really doesn't serve any purpose. I've taken off the rear wiper on all my previous hatchbacks (non-hatches dont have them anyway) and have no issues seeing out of the rear window in the rain. besides, between the rear defrost and the fact that everyone should have their headlights on anyway, its a non-issue.
    i flipped over the leftover rear grommet from the wiper arm to plug the hole in conjunction with an interior plastic clip at first. will look for a 1" nylon plug at the hardware store whenever i remember
  8. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    What LEDs did you use? I just bought the OPT7 Aurora kit and right now just have them connected to the CIG lighter because I am not very familiar with the fuses. Can you show a picture of the lights and how you mounted them?
  9. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I ended up removing the dome light and soldering wires to it and running them down the A pillar and under the dash. The lights I bought from Wal-Mart are strip leds see pic. The lights are attached under the dash with double sided tape for now, will most likely reinforce with zip ties.
  10. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    Ah yeah I don't want solder anything since my car is leased ):. This is what I got though so it comes.with everything and no need to solder but idk what fuse to plug into. 1492554357529.png
  11. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I watched a few you tube videos before I did the install and the systems like your recommended a fuse that has power all the time like the power locks (fuse 17 25 amp located under dash) or head lights.
    #1111 sph101, Apr 18, 2017
  12. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    So the fuses it came with say 10 on them. Should I go get a 25 ?
  13. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    This isn't fully installed yet but they still look awesome :D
  14. Sifugus
    Sifugus Junior Member
    Orlando Florida
    2015 Prius c
    Well I have put Tein 1.4 inch drop springs n riding on 215/45r17 .... runs great no rubbing...and working on doing more.... prius c will be different very different 20170423_005255.jpg
    cyeremian and edspecR like this.
  15. Veliksam
    Veliksam Member
    108
    61
    Orlando
    2014 Prius c
    Bought a new to me display audio HU, model number 100505 on eBay for $188.
    Anyone know if this has HD radio, I think it doesn't but I'm hoping I'm wrong?
  16. SwhitePC
    SwhitePC Active Member
    495
    214
    ca
    After much thought I finally decided to put in some LED bulbs for lowbeam and fog lights...Seems the OEM fog halogen bulbs are only a measely 10w compared to the led I put in of 50w comparable output
    I don't really notice any difference other than color temperature (since lowbeams are projectors)...but I guess it's like changing your house bulbs from soft white to daylight bulbs...the whiteness in light creates a placebo effect that you're seeing more/better? (just me)
    The led fog bulbs does shine more/better than the oem bulbs
  17. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    Changed my rain visors to the WeatherTech ones. Added carbon fiber panels.
    iPhone ?
    djdawn and J Buck like this.
  18. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    Put Plasti-Dip on my emblems. If I get tired of it, I'll just peal it off. I like it for now.
    edspecR likes this.
  19. cyeremian
    cyeremian Member
    142
    27
    SF Bay Area
    So, tell me about the emblems in the rear. I'm talking specifically about the "Prius C" emblem on the left side rear and the little rectangular one on the right side rear that says something like, "Synergy Drive." Are there holes underneath? If not, I'd like to just take mine off.
  20. djdawn
    255
    116
    Escondido, CA
    2014 Prius c
    I can confirm there are no holes under either. I've removed/relocated both emblems on my C as well.
