Replacement Key FOB
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Nathan Freed, Apr 26, 2017.
  1. Nathan Freed
    Nathan Freed Junior Member
    Guantanamo Bay
    What numbers exactly on the back of the key FOB need to be identical in order for the new FOB to be compatible with my one existing one and my 2013 Prius?
    The FCC ID? IC # ? Or the other small number below those two?
    Thanks.
  2. Currahee
    Currahee Member
    103
    34
    CT
    The IDs should be the same for all Gen 3 smart key fobs. You need Techstream or a Toyota dealer to program the new key to work in your car.
    Dyjital likes this.
  3. Nathan Freed
    Guantanamo Bay
    So as long as I buy a second fob with the same FCC ID I'm good to go?
  4. Currahee
    Currahee Member
    103
    34
    CT
    It's ready to be programmed, yes. I think the FCC ID is just the part model number plus some other digits.
  5. ChapmanF
    18,513
    For a Gen 3 with the remote air conditioning, the fob has an extra button. As far as I know, the FCC IDs are the same, as is the circuit board inside, there are just two versions of the front half of the plastic case, one without the extra hole and button. You just have to be sure you're ordering the version you want.
    If you're not buying new, be sure the seller says the fob is 'virginized'. Those will work, but they sell for more than just plain 'used' ones, which won't (unless you want to go through a whole ECU reseed on the car).
    -Chap
  6. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    As I recall, the most common Gen3 fob has an FCC id of 14ACX. There are others, so it's important to check.
    Dyjital likes this.
