Prius Prime Premium Fog Light Addition
Discussion in 'Prime Accessories and Modifications' started by sakozar, Apr 28, 2017.
  1. sakozar
    sakozar Junior Member
    Grand Rapids, Minnesota
    2023 Prius Prime
    XSE
    Does anybody know if fog lights can be added to the Prius Prime Premium? I know the advanced model comes with them but there weren't any for sale in Minnesota when I bought my Premium.
  2. MNdriver
    MNdriver Senior Member
    549
    577
    Nice looking car, Grand Rapids!
    sakozar likes this.
  3. PT Guy
    PT Guy Senior Member
    1,085
    713
    Washington, the state
    Really useless lights. They do a very small bit of good to light up the sides of the road. Don't worry that you don't have them.
    Lee Jay likes this.
  4. sakozar
    2023 Prius Prime
    XSE
    I know they aren't really functional. I just want my car to look even cooler than it already does (if that's possible). Love My Prime!!!!
    priuscatprimeguy likes this.
  5. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    You can buy the light assembly on eBay! I seen them out there I asked the dealer and the guy told me (he was a cool guy) that to buy them on eBay and install them yourself since it’s a plug-n-play assembly. Because if you have the dealer do it for you he said it’ll be $2,100. And on eBay you can buy it for $1,200~ and takes a few hours to do them. Plus you can sell your headlights on eBay and make some of that money back! I hope this helps (y)
  6. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    1200 dollars? What a rip off.
    Suds likes this.
  7. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    For both sides with bottoms and housing? Not really, espically new . Unless you’re getting used
  8. a_gray_prius
    2,927
    783
    IL
    Agreed. $1200 isn't bad at all - replacing OEM housings on our Gen2 was like $900 last I checked.
  9. PHV PLS
    PHV PLS Member
    157
    81
    2017 Prius PHV
    I hold true :cool:(y)
  10. scubasteveorino
    scubasteveorino Junior Member
    Massachusetts
    Hey PHV PLS, I'm actually thinking of attempting this conversion project, but don't know what to expect or if it really is possible to do.
    Has someone at the dealership you talked to about this attempted such a project? If so, do you know if one installs this, would just the 3 bottom white LED sidemarker lights function when the headlamps are on, but the fog lamp itself can't be switched on because the Prime Premium doesn't have the fog lamp turn signal stalk switch knob? I also don't know if the proper relays are installed on the Prime Premium to support this new light assembly, but any info you can share from that guy you talked to would be really helpful if he had completed this project himself before. Also, to replace the OEM turn signal stalk with the fog lamp switch looks like a huge hassle to do and I don't trust myself to do that kind of work as I'd be afraid to break something on a nearly new car.
    Thanks for your help!
    GTprii likes this.
  11. Sezy
    Sezy Active Member
    443
    231
    37
    Saint Charles, Missouri
    2020 Prius Prime
  12. Prime Alex
    Prime Alex New Member
    29
    Manitoba, Canada
    2020 Prius Prime
    Upgrade
    You got that right. I keep turning them on whenever visibility is lower just in case it might help... but no. Mind you, I haven't tried in actual fog, so there's that.
  13. citiprius
    citiprius Active Member
    241
    238
    51
    2018 Prius Prime
    For the look, try this:
    MrBugMan likes this.
  14. motch6
    motch6 Member
    44
    34
    UTAH
    2020 Prius Prime
    HOW is this car even Drive-able? Those tires won't turn past the fender! bwhaha!... This car must have a hydraulic system in it, so it can get off the ground to drive! ;)
    Why would anyone do this to a Prime? heh.
  15. MrBugMan
    MrBugMan Junior Member
    Earth
    2018 Prius Prime
    I think it looks pretty cool and can def appreciate all the work that went into creating this ride.
