Proactively replacing 12v
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by markabele, May 2, 2017.
  1. markabele
    5,084
    1,782
    Nebraska
    Has anyone replaced their 12v before truly needing to do so? Any wisdom in this?
    Mainly asking the 2012 guys/gals, but maybe someone in a 2013 has already done it, as well.
    Thanks for any feedback!
  2. Mendel Leisk
    41,808
    Sure, every 4~5 years, regardless.
    jerrymildred likes this.
  3. Potorap
    Potorap Active Member
    345
    148
    Pahrump, Nv
    I have a 2013 and have been considering it myself. However I do use a battery tender nearly everyday to keep it topped off. I would like to replace with a full size battery but have not looked to deep yet. Just a thought. My other thought is how many times have you drain your battery? That would be a determining factor for me. Obviously the more times you drained it to where you needed a jump takes some of the life away each time.
  4. Mendel Leisk
    41,808
    Check with something like Solar BA5 first, too.
  5. bisco
    52,260
    I have never entertained the idea. Batteries don't just drop dead, they slowly degrade. So, I keep an eye on it. Mine almost like new at 50k.
    Now if I had ever drained it, that would be a different story. They don't play as nice after that.
  6. markabele
    5,084
    1,782
    Nebraska
    I have never drained mine either. Maybe I'll consider it in another year though.
  7. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    2012, 50K miles. The original battery settles down to 11.9 volts soon after unplugging. No performance issues yet, but I thought I'd try to bring the voltage up by using a BatteryMINDer Charger/Maintainer/Desulfator System - Model# 1500.
    Raytheeagle and bisco like this.
  8. Mendel Leisk
    41,808
    It's time.
    giora and Yea Right like this.
  9. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    I change mine every 4 years.
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    It's past time.
  11. bisco
    52,260
    i wonder why, has it ever drained?
  12. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I replace the 12V battery when it dies twice in a short amount of time. I'm still on the original battery. The first time, I probably left a light on. The second time the battery is probably dead. A dead battery won't strand me on the side of the road. A dead battery will strand me in a parking lot or at home or at work. Some one will be available to help me. That's how I look at it anyway. If I go to long term airport parking lot or some kind of trip, I bring my portable battery jumper/air compressor USB charger/flashlight/beacon.
    bisco and Raytheeagle like this.
  13. Tideland Prius
    16,597
    I replaced my 2010's 12V at 80,000 miles (7.5 years). It was still running ok but I thought it's been long enough. I guess I could've taken a volt meter to check for sure but I'd rather not be left stranded.
    Tracksyde and bisco like this.
  14. bisco
    52,260
    a jump pack is a handy thing to have, and then you can hang onto your 12v to the bitter end.
  15. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    2010 Prius II purchased in August 2009 and still have the original 12v. Just took a week long trip and left the Prius in long term parking. When I returned this afternoon, it started up:).
    But I carry a portable jump pack and use the Battery MINDer 1510 monthly to ensure it stays in working order. It has never been drained down, so I feel comfortable "rollin' the dice" a little longer.
    But do what you feel comfortable with (y).
  16. mmmodem
    2,732
    1,703
    Bay Area, CA
    That is some miracle 8 year battery you got there. I keep reminding myself to buy the 1510 but still haven't.
    Next time, give me a call and I will drop you off at the airport. Don't pay those ridiculous long term airport fees. :eek: I got an SUV now.
    Raytheeagle likes this.
  17. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    The 1510 is around $49 on Amazon currently. Put it in your cart and I'm sure it will arrive;).
    Thanks for the offer on SFO. It was $25 a day for long term parking, so it makes sense. Next trip I am also considering BART, and leaving my car with a coworker or something. $25 a day is highway robbery :sick:!
    We'll have to see next time (y).
  18. Pluggo
    608
    534
    Yeah, I know you're right
  19. Mendel Leisk
    41,808
    We dropped our daughter and son in law's vehicle at YVR, around 11pm, when they were coming home. They drove out around 2am. The charge: $60. Two days you see.
  20. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    Ouch:(.
    Interesting how it is not a rolling 24 hours, but a calendar distinction.
