Handling during a sudden stop
Discussion in 'Gen 2 Prius Main Forum' started by PriusRos, Jun 26, 2006.
  1. PriusRos
    PriusRos A Fairly Senior Member - 2016 Prius Owner
    1,973
    218
    Rockville, MD
    I've had my Prius for about 10 days now and have been really happy with it except I was a little put off by the handling.
    The other day, I had to brake fairly suddenly -- it wasn't that sudden because I never follow anybody closely, but I was probably going around 55 mph and realized that traffic ahead of me had slowed down a lot. I don't remember the road being wet or anything. When I braked, I felt the car swerve and I had to grab the wheel hard to regain control.
    Is this a common problem with the Prius? I don't have VSC. My previous car was a 1996 Infiniti and I felt it handled much better. Is there something I should be doing differently (apart from not braking so hard)?
  2. mkaliski
    mkaliski Junior Member
    27
    Columbus, Ohio
    <div class='quotetop'>QUOTE(PriusRos @ Jun 26 2006, 05:32 PM) [snapback]276997[/snapback]</div>
  3. ScottY
    ScottY New Member
    1,250
    Long Island, NY
    I am not sure if this is your case. When my front right tire was low on pressure, the car turns right when I brake. After I make both front tire the same pressure, it never happen again.
  4. mkaliski
    27
    Columbus, Ohio
    I have a 2005 Prius with VSC and also had to stop quickly on the freeway. The rear of the vehicle suddenly swerved almost in to the other lane. It appeared as if the brakes locked. Conditions were dry and temperature was warm. I assumed that ABS should have prevented this but I guess not. No real answers to the handling issue.
  5. CrazyRussian
    CrazyRussian Junior Member
    42
    <div class='quotetop'>QUOTE(mkaliski @ Jun 26 2006, 02:52 PM) [snapback]277003[/snapback]</div>
    What was others' experience??? Mkaliski, what was the tire pressure at the time? This is kind of bothersome taking in account that the car has VSC and ABS....
  6. brandon
    brandon Member
    771
    Manhattan, KS
    No problems here. The various safety features did their job (2005 Prius w/ VSC). Most memorable experience was when the traffic came to a sudden stop on the downhill of a highway. No swerving as you describe, although I could "feel" the car making some adjustments I was not, but then again, that's what those stability features are designed to do.
    I should add that some (perhaps most) drivers instinctively jerk the wheel when something suddenly happens in front of them, which consequently can cause a swerve and/or loss of control. Are you sure this is not the case in your situation?
  7. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(brandon @ Jun 26 2006, 08:07 PM) [snapback]277079[/snapback]</div>
    No, I am pretty sure I don't do that. As I said, I did not experience this swerve with my previous car. The other thing was, I wasn't swerving to avoid something -- just trying to stop quickly because the traffic in front of me had slowed down.
  8. ceric
    ceric New Member
    1,114
    Fremont, CA
    If the tire pressure is normal, I would check the brake pads next. Even though, nowaday, pads are simply "floating" on rotors, sometimes, left/right sides simply grab the rotors differently. When braking hard, the vehicle may pull to one side.
    In addition, Prius is a front-heavy (59/41% front/rear) vehicle (like most front drive) with tall stand (higher than most sedans/coupes). When braking hard, the rear end would be lifted due to weight shifting forward. The rear tires would lost traction a little. Therefore, it may be more likely to fish-tail. Just my assessment.
  9. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    No problem here either. Just had to make a sudden stop the other day...everything went fine. I agree, a lot of driver's instinctivly jerk the wheel trying to avoid what is in front of them. It happens so fast that it is not a conscious reaction, so one would not remember doing it. Most of us are also used to pumping the brakes which is a hard habit to break with the new ABS systems.
    However, sounds like you did not crash, so I guess things worked as planned as far as that.
  10. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(mssmith95 @ Jun 26 2006, 09:04 PM) [snapback]277103[/snapback]</div>
    I had ABS in my last car so I'm used to braking with ABS. And yes, you're right. I didn't crash of course. But the jerk to the side did bother me.
    <div class='quotetop'>QUOTE(ceric @ Jun 26 2006, 09:01 PM) [snapback]277098[/snapback]</div>
    Car is brand new and has only been driven 500 miles. I would expect the tires and brake pads to be up to spec.
    Thanks for the input and suggestions, everyone. I'm a little disturbed that a couple of others seem to have experienced something similar, so it could be the car and not just me. I just hope that I can get used to the handling.
  11. barbaram
    barbaram Active Member
    912
    70
    Trenton, NJ
    I've had to stop a bit faster than I originally anticipated.
    Throw the shift to B and brake I've found a big increase in braking effort and no problem stopping where I needed.
  12. offersk
    offersk Junior Member
    DC
    I experienced the exact same swerving after a sudden stop several times soon after I bought my car. I have a 2006 Prius, HK model #6 with ABS, traction control VSC, etc. I was going about 60 and slowing down to 30 mph on a dry road and the back of the car didn't follow the front of the car during the stops. I expected a straight controlled stop, but what I experienced was anything but. After having the car for 5 months, I haven't experienced anything like that recently. BTW, I have had Michelins on my car since day one, so this is not a tire problem nor is it a tire inflation issue.
  13. ttabbal
    ttabbal New Member
    I had to brake and swerve to avoid an idiot Mini driver that got on the freeway slightly ahead of me (we were about even when he started this) and proceeded to fly across all 4 lanes of moderate traffic without looking, signalling, or even getting up to speed. I would guess they were going about 50 MPH durring this lane jump.
    The ABS kicked in, Trac for a minute as I hit a little gravel. No VSC chime. I was able to brake HARD, and control the car just fine. 2006 #6. I thought the Prius handled the emergency braking quite well, much better than the other cars I have owned. I was going about 65 MPH in cruise at the time.
  14. bruceha_2000
    bruceha_2000 Senior Member
    3,057
    302
    Northwest VT
    2018 Prius Prime
    <div class='quotetop'>QUOTE(mkaliski @ Jun 26 2006, 05:52 PM) [snapback]277003[/snapback]</div>
    I wonder if there would be any codes Toyota could pull. The brakes shouldn't be able to lock, not with ABS.
  15. jbarnhart
    jbarnhart New Member
    629
    Santa Clara, CA
    <div class='quotetop'>QUOTE(ceric @ Jun 26 2006, 06:01 PM) [snapback]277098[/snapback]</div>
    If it's a U.S. car -- no pads, no rotors. We have four drum brakes in the U.S. :eek:
  16. kstorey
    kstorey New Member
    <div class='quotetop'>QUOTE(jbarnhart @ Jun 30 2006, 01:28 PM) [snapback]279195[/snapback]</div>
    Actually, 2006 have discs on the front, drums on the back.
  17. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(priusmatic @ Jun 30 2006, 10:58 AM) [snapback]279210[/snapback]</div>
    Not just 06, all the 04 thru 06 have disc front drum rear in the U.S. and Canada. I think the earlier G1 is the same.
    If I had the problem described I would try to duplicate it, after checking tire pressure of course. I have taken mine to a straight road with no traffic and crammed the brakes on as hard as I could to check ABS operation. I would rather find a problem that way than during a panic stop. It also lets me know what to expect. I think the brakes should have a couple of thousand miles on them first though.
  18. PriusRos
    1,973
    218
    Rockville, MD
    <div class='quotetop'>QUOTE(tumbleweed @ Jun 30 2006, 02:22 PM) [snapback]279228[/snapback]</div>
    Yes, I am planning to test them that way as soon as I get a chance. I have done some hard braking at slower speeds on side roads and don't have any problem but haven't yet had a chance to go on the open road and test them at highway speed. Empty highways are not easy to find in the DC area!
    I only have a few hundred miles on the car so I'm hoping that the brakes will "settle in" after a while.
  19. tumbleweed
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(PriusRos @ Jun 30 2006, 11:36 AM) [snapback]279235[/snapback]</div>
    I agree brakes need to be "broken in" for a while, of course sometimes you have no choice except to step on them hard, such as in your situation. I tend to forget how busy roads are in some areas, around here it's no problem. But I think it would be worth it even it you need to go out into the Maryland countryside early Sunday morning or something. Let us know what you find.
  20. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    <div class='quotetop'>QUOTE(jbarnhart @ Jun 30 2006, 10:28 AM) [snapback]279195[/snapback]</div>
    Even someone who knew nothing about the Prius could look through the openings in the front wheels and see that there are disc brakes there (and drums in the back).
