Causes of LOW MPG Average?
Discussion in 'Gen 2 Prius Fuel Economy' started by Hutchings, Jun 26, 2006.
  1. Hutchings
    Hutchings New Member
    Hello friends, I am a newbie here, so please be gentle with me... I have already gained a huge amount of information here and at with my wife's encouragment (ok, she made me post this) I have a MPG question.
    We traded in our Suburban for our new Prius and have been simply amazed at how our fuel bill has drastically changed. We are equally impressed with the incredible mileage we have attained. However, Here is our observation. Once we fill up we reset the trip odometers ( A and B ), and as soon as we start driving again, the average MPG rating resets as well. The issue I think we are having is that the average MPG never has gone over 45.0 MPG. We notice it hovering around 44.7 - 44.9, only occasionally reaching the 45 MPG rating on the MFD. So, once I leave Costco, having reset the trip odo's , I find that even while on battery only, that I still can not quite get 'er up over 45MPG. We have no MODS (other than the reverse beep disable) and use the AC/AUTO function most of the time. We use our headlights full time and keep the cabin temp around 72 degrees. My wife and I challenge eachother who can drive the smoothest, in efforts to bring the average up, but to no avail. We do nice and easy starts, take advantage of regen braking and are very light footed. We have also tried to "glide" (I think thats what its called) when there is no comsumpsion fromeither the battery or the engine. We kind of glue ourselves to the MFD. In our quest for more MPG we also have noticed that the ICE seems to like to run, even when we don't think it had any reason to start.
    We have done the actual math (gallons used vs miles traveled) and have come to the same conclusion, that we are simplynot getting the premimum mileage we think weshould be getting (and like most members here are getting). Am I doing something incorrectly or can someone advise me if this feeling is justified?
    Just for kicks and giggles, we tried to run without the ac ( yikes-103 degrees here today ) or the headlights on and it did not seem to make any difference.
    So far, 2600 miles, and nearly 3 happy months of ownership. Verypleased with the technology and can't wait for my daughter to start driving so I can buy her a Prius as well.
    And finally...I am confused what is actually happening when on the MFD, the battery level turnes from blue to green? Humm....
    Thanks in advance for your comments friends and looking forward to future participation in the groups.
    Stephen
  2. slortz
    slortz New Member
    316
    Welcome to the club!
    45mpg is not too bad. I think one question is what is the average length of the trips you are taking. My daily commute is only 8.5 miles each way (about 30min) which is not good for mpg--the ICE gets fully warmed up and is most efficient just about the time I arrive at work and shut off the car. :(
    My MPG average tends to shoot way up when I take longer trips, even on the freeway.
    Still, I could get 50mpg with short trips but I would have to work at it MUCH harder...via slow steady acceleration, pulse and glide, coasting down to stops, etc. I think if you keep working at it and experimenting you will get there.
    Try perusing the posts in this forum 'cause there are lots of tips and theories on how to maximize your MGP. Good luck! :)
  3. Tideland Prius
    16,501
    hmm... thanks for putting the location in your profile, it makes answering the question a lot easier.
    It seems odd since isn't Eastern WA more or less flat? Or do you live in the hilly parts near the passes? You seem to be doing well and no doubt you'll be able to improve. Turning off A/C should make a difference since the A/C isn't draining the battery, leaving you more juice for powering the car if needed. Also, if the A/C is running at full blast to keep the temps down (should be in 90s this week), then your mileage will take a hit. Try bumping the A/C up as high as you can stand without overheating or feeling uncomfortable. Also, make sure you're not taking short trips. Short trips will erode the nice mileage quite quickly. By short, I'd say a 5 min drive? or a quick sprint up a hill then stopping.
    Headlights won't make a difference.. or at least not a big enough difference to notice.
    For the battery, nothing. It's colour-coded so it's easier to read. green is much easier to see than counting 7 bars. 7 and 8 bars are green, 3-6 are blue, 1-2 are pink (or purple, depending who you ask).
    Keep up the techniques you're using. I don't see any problems with that. You might crack the 50mpg in late Aug or early Sept before the cold temps set in and the switch to winter fuel.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
  5. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    Evan's link above is possibly the best advice available for anyone concerned about their MPG. check it out and see how you do :)
    and pff, how can i forget, WELCOME to the fourm! feel free to stick around, check out the features of the site (Danny has set up a fantastic set of resources here)- check out the "features" menu on the top right of the page and browse around a bit.
  6. Hutchings
    Yes, here in the Tri-Cities, we are very flat. Dry and dusty too! 95% of our trips are less then 15 minute outings. I will keep following the sugestions offered and appreciate all of the replies. Sure love this Prius. Too bad it still fits over 250 bucks worth of groceries from Costco in it. I kind of hoped that my wife expensive weekends at Costco were over, but nooooo, darn thing has too much cargo room!
  7. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    I'd suggest you check your car by forgetting tank mpg and trip mpg. Look at your steady state mpg at a fixed speed on level road over a few minutes after the car is fully warm and you are in stage 4.
    Note the temperature and humidity too. Then plug into Wayne Brown's palm program if possible, or else look up some of the tables of mpg vs speed that have been listed here based on this simulator.
    If you do this when there is minimal wind, you should get a good idea how you are doing.
    Note that you may need over 12,000 miles on your car to get as good mpg as others here report.
    After doing this, try a loop of about 30 miles or more on back roads where you can drive steady at speeds of 35 to 40 mph. Do not pulse and glide. Just drive steady. Find a route where you have minimal stops.
    With AC off, you should be able to exceed 70 mpg. Reset your mpg when starting. It is far more useful on trips than measuring tankfuls which you can calculate anyway. After you do this and see great mpg hopefully over 70 mpg you can then work on things like pulse and glide to try to do better. Till you get the basics right trying the fancy stuff might just make things worse for you.
    Now if you can get good mpg, just somewhere, you can then learn to see why it is bad in your normal driving. Could be trip lenghts, not getting into stage 4, AC use, really big mountains, too many stop signs or bad traffic, etc.
    When you can be comfortable turn off the ac and open windows. Every time I've tested, mpg has been better with AC off in temps up to 85 degrees. If you drive 80 mph maybe AC is better than opening windows but then you won't get great mpg anyways.
    Finally remember brakes are for emergencies. If you use them to stop fast or to stop every mile or two your good mpg will be gone.
  8. Jeannie
    Jeannie Proud Prius Granny
    1,414
    Central New Jersey
    <div class='quotetop'>QUOTE(galaxee @ Jun 26 2006, 07:29 PM) [snapback]277052[/snapback]</div>
    Ditto
    I had the same concern on my first tank and posted much the same question. That link explains a LOT!
    I drive short trips - 5 miles each way to/from work. I'm half-way through my 4th tank of gas; first tank averaged 43 while I "learned" to coast as much as possible to slow down, anticpate the lights on my daily route, etc. It was easy to learn by just glancing at the 'consumption" screen and noticing the 'instantaneous' reading - example - there's a half mile stretch of road between two stop lights, and the second light says 'no turn on red'. It's a 'back way' with a 30 MPH speed limit. Often there's no one near me on that stretch of road. If I keep my foot on the accelerator to maintain a speed of 30, I ALWAYS have to stop for that red light. If, on the other hand, there's no one behind me, I'll 'coast' and perhaps tap the aceelerator when I slow down to 25, unless I'm very close to that stop light - I've let it drop down to 15 mph and still have to stop at that light. I then turn right and go through a small town for maybe 1.5 miles, where the speed limit's 25 or 30 - I rarely try to push myself up to 30, because shortly after the change in speed limit from 25 to 30, the road dips down for a bit - the car will get up to 30 without my stepping on the accelerator.
    So my next couple of tanks were about 48 mpg, and the fourth tank looks like it's heading the same way, and I'm not likely to see much of an improvement until I happen to take one or more 'long' trips on a tank of gas, where 'long' means driving for 45-60 minutes instead of the typical 15 to 20 I drive on my commutes and the even shorter times for my 'errands'.
    Several people have said they see an increase in MPG around 3000-5000miles, and some say that's because the tires are now 'broken in'.
    Good luck with your mileage. I'm thrilled to be getting at least twice the MPG as my old car! So this is my wisdom after 10 weeks of ownership <g>
  9. haceaton
    haceaton New Member
    27
    <div class='quotetop'>QUOTE(tomdeimos @ Jun 26 2006, 07:41 PM) [snapback]277058[/snapback]</div>
    This is a great suggestion. I've only put about 500 miles on my new '06 and have averaged a sad 40.2 MPG so far. I also have an '02 Prius and I've driven it since Oct 2001 and have a lifetime average of 44 MPG on that vehicle. So I'm not a newbie to driving the Prius for good mileage. This time of year my '02 gets about 48 MPG with the same kind of driving I've been doing in the '06. Theoretically the '06 should get better mileage than my '02 but so far I wonder if there is something not quite right with the car. It's definitely not the A/C, since I sweated it out for about 100 miles without using A/C and saw only a miniscule improvement.
    Like the topic starter of this post, I notice my '06 starting the engine when it really seems like it shouldn't. For example, going down a hill with the foot completely off the accelerator pedal at a speed of 36 MPH, and the engine starts! The battery icon shows 4 bars and the A/C is off, so I can see no reason to start the engine when it was just running on the way up the hill and shut off when I first took my foot off the gas.
    One other thing I notice is that the starting and stopping of the engine is far more noticeable in the '06 than in my '02. I can feel a small but distinct "bump" in the car acceleration most of the time when the engine starts or stops. My '02 is much smoother in this regard, it's relatively rare that I feel its engine start/stop.
  10. jkash
    jkash Member
    889
    West Hills, CA
    <div class='quotetop'>QUOTE(Hutchings @ Jun 26 2006, 04:40 PM) [snapback]277057[/snapback]</div>
    Your short outings are your biggest problem not achieving higher mpg. You need to drive at least 30 minutes to make up for the first five minutes being low due to warming up. I have to admit that I try to have my wife drive her car if we are going to do a short trip. She thinks I am a bit of obsessed, but she's getting over it. :lol:
  11. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    Stephen,
    Are you actually pressing the button on the MFD to reset the MPG display?
    Although I have seen it written that it resets automatically after refueling, for me it seems to be that the distance reading resets to zero but the MPG figure does not unless I actually press the RESET soft button on the display.
    If you didn't reset it then what you have displayed is the MPG figure since you bought the car. That figure will change very slowly over time.
    After a reset the MPG figure changes very rapidly - go up a small hill and it will plummet, coast a bit and it will rise to a very high figure.
    kevin
  12. savaged
    savaged New Member
    <div class='quotetop'>QUOTE(kevin17 @ Jun 26 2006, 11:06 PM) [snapback]277160[/snapback]</div>
    Bingo. I'll bet that's your problem! (As mentioned, trip length is also a major factor I've found)
  13. Hutchings
    I have been only resetting the trip odometers, which in turn resetted the miles in the MFD as well. I have not reset it via the MFD, however that does make sense. We saw the miles driven reset and I guess we assumed that it reset the MPG figure as well. I will post back tomorrow when I explore that further. Thanks a bunch for this ( seemingly obvious ) procedure. I am anxious now to go try it except its quite late, and now past my bedtime.
  14. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(Hutchings @ Jun 26 2006, 07:40 PM) [snapback]277057[/snapback]</div>
    There's your answer. The shorter your trips are, the lower the MPG you will get. The longer your trips are, the higher the MPG you will get.
    This is all because of the first 5 minutes of driving when the Prius runs less efficiently during its warm up cycle.
    You have probably noticed on the Consumption screen that the first 5 minute bar on the graph is usually always between 25 and 35 MPG. Then the next bars are probably much higher, in the 45 to 60 MPG range. It's that first 5 minutes that is bringing you down.
    Lets say you always make 15 minute trips and that you get 30 MPG for the first 5 minutes and 55 MPG for the last 10 minutes. If you do the math, you will find that (5x30 + 10x55) / 15 = 46 MPG. However, if your trips are always 20 minutes instead, you get (5x30 + 15x55)/20 = 48 MPG. 30 minute trips result in 50 MPG and 10 minute trips result in 42 MPG.
    It's as simple as that. You can drive as carefully and smoothly as you want and you will still be limited by the percentage of your trips that is taken up by the warm up cycle.
  15. haceaton
    haceaton New Member
    27
  16. Hutchings
    Tuh-Duh! We reset the mileage on the MFD before we left this afternoon, and now I am getting the results I was looking for. I did not realize that you could reset the "lifetime" mileage. I guess it was a lifetime reading since I had never reset it. Now, for our 15 minute trip to grandmas house, she averaged about 52-54 mpg. I now reason that had we not reset the MPG reading, that it would have eventually come up as our mileage consistantly improved. I now see the procedure for an accurate reading from tank to tank, which shows us the results of our driving patterns. My wife is pleased again, and I feel much better that we are actually getting the better mileage you all have boasted. I am walking a bit taller this afternoon and feeling quite proud again! Thanks for the offerings and sugestions you haved all posted. I read aloud with my wife, the article on factors that imped you mpg and will start on some of those ideas too. I like that comment that brakes are only for emergencies! Thanks again all, hope to run into you all again soon on the boards.
    Stephen
  17. rak
    rak New Member
    In our first 6 months (2005 model), we never got better than 35 mpg (yikes!), and now, it's tough to even pass 44 - so you're already ahead of me. After reading other posts, I realize it's mostly because my trips are very short, and we have stop signs or pedestrians crossing or unavoidable stop lights at least 4 times per mile. I've been trying to do more of the glide thing, but it doesn't seem to be enough to make up for the things I mentioned. On the other hand, others around here (Berkeley) do get in the 50's - maybe their trips are longer?
  18. Maytrix
    Maytrix Member
    742
    Marlborough, Mass
    This must be new as my 2005 resets both the MFD mileage and average mpg readout each time I fill up.
  19. rumpledoll
    rumpledoll Member
    179
    46
    New Jersey, USA
    We are the same way. My wife uses the car during the week, and the vast majority of her trips are shorties with the car barely going beyond that first 5 minute bar. Are mileage here in NJ (2007 std. Prius) is ~34MPG winter and ~43MPG summer. When we take out the car for longer trips and P&G, the mileage can often be 50+.
    On the other hand, we still keep our 2002 Ford Explorer for those hauling needs (e.g. taking my telescopes and gear out to a dark sky location, Prius cannot hold that stuff) and I used it this past week doing the short trip driving and it now has 9MPG for the ~60 miles - so we are kicking butt with the Prius!
