Issues at higher speeds and brakes
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bye civic, Mar 21, 2016.
  1. bye civic
    bye civic Junior Member
    Chicago
    I'm looking to buy a 2010 prius. Got my eye on a IV with solar powered fan top with 165k miles. I made the point to get on the highway at the test drive, when i got up to around 60 and took my foot off the gas it seemed to decelerate a bit faster then what i'm normally used too. It also seemed like the acceleration was a bit jerky at the high speeds and a bit more road noise then i would like for a newer car (i've been driving a manual trans 99 civic for comparison for a decade). I'm not sure if the high winds we had that day played a factor of this is just how hybrids feel at higher speeds. I test drove a 2014 with low miles and noticed this as well...but to a lesser extent. other then that i like the car. Glad the power drive option is there or the acceleration would bother me. Brakes seemed a bit too spongy but the dealer said that is common for Toyotas. Not sure if that is a line or not. Any feedback will be much appreciated thanks.
  2. Mendel Leisk
    41,748
    PWR mode has to be selected each time you start the car. Also, it only remaps throttle response; it doesn't increase power. I'd suggest to leave both PWR and ECO off, the default "normal" mode, it's very linear.
    A tri-yearly brake fluid change is advocated (by Toyota Canada at least), might help with soft brakes. Also, a thorough brake inspection could be overdue.
    When lifting right off the gas the car will start to regen a bit, using momentum to charge the hybrid battery. If you want to keep it more free wheeling, maintain a slight amount of pressure on the gas pedal. It's not giving gas so much as just alerting the computer to hold off on the regen.
    I came from an 06 civic hybrid, was a little askance at first, but that wore off real quick. I get to drive that civic occasionally, definitely not in the same league, gas pedal very touchy, off/on.
    #2 Mendel Leisk, Mar 21, 2016
  3. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    If you are on cruise control, and speed up, it will slow back down to the set speed quite rapidly.
    When not on cruise control, it is a much slower deceleration.
  4. Bay Stater
    Bay Stater Senior Member
    534
    771
    Central Mass
    Could be attribute to worn uneven tires, car out of alignment, or warped brake rotors. The car does have 165K miles so any of these are in play. Good luck with your Prius pursuit!
  5. bisco
    52,188
    welcome o/p, i think you've nailed it. question is, can you live with it?
  6. bye civic
    Chicago
    Thanks for the replies everyone. Can i live with it? i could get used to it..as long as the ride is smooth in cruise control. but right now convincing myself to pay close to 9k for a car with 163mi is the hard part.
  7. bisco
    52,188
    can't blame you there, sounds too expensive.
    Tande likes this.
  8. belkyrnn
    belkyrnn New Member
    Alabama
    I got my 2010 Prius IV for around 10k and it had 96k miles. It does not have solar powered fan top package, although. But still 9k for 163k miles sound too expensive.
  9. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    163,000 miles and a Chicago car? Don't do it...and don't be swayed by the toys. You can do a lot better with $9,000.
    Tande likes this.
  10. Bay Stater
    534
    771
    Central Mass
    9K for a 6 year old Prius with 163K miles does sound high. Is that at a used car lot? If it were me, I would pass and continue to shop around for one with less than 120K miles.
  11. bye civic
    Chicago
    I bought the car. put on 20k so far...a lot of that for uber. the issues with the acceleration were moot...havent had any issues. side air bag recall was a breeze.
    Lightning Racer and mmmodem like this.
  12. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I think you're describing attributes which are subjective. Noisy? Spongy? Sluggish? Compared to what?
    I suggest you test drive a much newer, low-mileage 2014 or 2015 Prius, which are the last years of Gen III. This should let you know how the car is supposed to feel when driven.
    That said, if you want to drive your car like you're Mario Andretti, don't buy a Prius and don't complain about it. The Prius is a 45-50 MPG car, and it has the lowest maintenance costs of any car sold today. But if you want a car that's zippy and delivers quick acceleration, buy something else. Anything else.
    kc410, Tande and Raytheeagle like this.
