Blind Spot Monitor or Compact Spare
Discussion in 'Gen 4 Prius Main Forum' started by EnglishSetter, May 5, 2017.
  1. EnglishSetter
    EnglishSetter Junior Member
    PA
    The hybrid battery on my 2006 Prius (143,500 miles) died and I would like to buy a 2017. Unless I'm reading the specs wrong, I cannot get the blind spot monitoring unless I give up the compact spare. Am I reading these specs correctly?
  2. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    You're correct - only the 4 and 4 Touring have the Blind Spot Monitor. Those versions don't have the spare.
    kevin
  3. yeldogt
    yeldogt Active Member
    810
    313
    NE
    They don't want you to get hit while drive with a flat tire.
    RCO likes this.
  4. EnglishSetter
    PA
    Thanks. Now I know what my trade off is. Like others, I wish the 4 came with a spare.
    RCO likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Something to consider - Blind Spot Monitor, if you want it, can't be retrofitted. A Spare Wheel, pretend type (or a full-size with even more difficulty & compromise) can, at a pinch, be retrofitted - though it takes a bit of messing about to do so.
    bhtooefr and RCO like this.
  6. Tideland Prius
    16,597
    That's true. A spare tire is easier to retrofit than adding two radars, an ecu, wires, new mirrors, rejigging the MID software to access the BSM settings etc.
    RCO and alanclarkeau like this.
  7. Iamjo20
    Iamjo20 Member
    259
    Kind of a weird trade off?
  8. Mendel Leisk
    41,808
    I'd go for the spare, and grumble.
    RJS5586 likes this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Me too. How on earth did anybody for before they put blind spot monitors on cars? Beats me. :sneaky:
  10. RJS5586
    RJS5586 Junior Member
    Tampa
    I would opt for the spare, as well. I was only looking at the Two. The dealer had only a Two Eco on the lot when I went there to test drive. When he showed me the can of fix a flat in the trunk, I shuddered. Call me old school, but I want a spare tire.
    And, I only had to wait a week for them to get me a Two.
    My wife has the blind spot monitor in her Highlander, and it's a neat feature. But, it doesn't tell me anything I already don't know. I don't fully trust it and look anyway.
    RCO likes this.
  11. yeldogt
    810
    313
    NE
    I own 15 cars (company and personal) ... we have used a spare once in 15 years.
    krmcg and ATHiker like this.
  12. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I went for BSM instead of the spare on my 2016 model. I'm glad I did. It has been a tremendous safety feature for me. I find it very difficult to see those blind spots.
    krmcg, ATHiker and RCO like this.
  13. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    I'll chime in with a vote for BSM. As said, a spare can be easily added for a cost ($$ and weight). The BSM has already paid for itself in two situations I can recall where, if I had not noticed the warning light, I would've caused a serious collision.
    I check my mirrors and turn my head to check blind spots all the time, but we all make mistakes. Sometimes that car that was two lanes over decides to merge toward you just after you check that blind spot.
    BSM, no regrets.
  14. Mendel Leisk
    41,808
    This either/or situation puts potential buyers in a quandry though. Maybe of interest to @Prius Team ?
    RCO likes this.
  15. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    I would choose the factory BSM over the spare because like others have said, you can't retrofit a factory BSM system but you can easily retrofit the factory spare tire. The cross traffic alert portion of the BSM is well worth the money. It picks up not only cars but other moving objects such as bikes, skateboard and people running. Please don't think you can just add aftermarket BSM. Current sonar sensors based BSM system doesn't work on hybrids. You get false alerts. check out this video on a 2012 Plugin Prius. It clearly shows false alarm with no cars anywhere close to the PiP. Even the Gosher's site says not recommended on hybrids or EV. They are coming out with a radar based BSM that cost twice as much that'll work with hybrids and EVs. For that money, I would spend it on spare tire kit because aftermarket BSM kits won't do cross traffic alerts. No aftermarket systems do.
  16. Tideland Prius
    16,597
    Also note you won't be able to install the front sensor if you have IPA (2010-2011 Prius V/Five w/ ATP) because the IPA sensor is roughly in the same location as those installed in the video above.
    RCO likes this.
  17. Iamjo20
    Iamjo20 Member
    259
    so how do you retrofit a donut in 4 Touring?
  18. cproaudio
    2,401
    762
    CA
    I thought I've seen a thread detailing how to retrofit a spare in a non-spare Prius. You gotta search for it.
  19. alanclarkeau
    7,045
    7,593
    Side vision was much better:
    kithmo and Mendel Leisk like this.
  20. Mendel Leisk
    41,808
    I would take the spare over blind spot monitor: to completely retrofit the spare, per a level 3, is well over a grand.
    RCO likes this.
