Back seat removal
Discussion in 'Gen 4 Prius Accessories and Modifications' started by randomwalk101, Mar 28, 2016.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    anyone has instruction on how to take out the back seat on a 2016 Prius?
    Also, the front I'm sure there are sensors down there...should the negative battery be disconnected before taking them off? Thanks
  2. DustBunny
    DustBunny New Member
    Helena, MT
    Four Touring
    I'm interested in this also.
  3. Mendel Leisk
    41,808
    During the Vegas reveal the Priuschat team managed to yank one off. I believe you just feel with your fingers for the hook points (2?), grab there, yoink up fast and hard.
    @Danny , please look into the posting delay issue.
  4. ChapmanF
    18,435
    That's been the procedure from the first, in my old Gen 1 it would always pop right out with a good honest yoink.
    On this Gen 3 I've lately acquired, I found the hooks were more stubborn. I did succeed in yoinking the passenger side out, after several tries, and crouching down in the back to brace my elbows against things and make leverage.
    The driver's side just laughed at all the yoinking I could throw into it.
    I eventually wrapped a 1x2 in some cloth, stuck that under the lip of the seat and popped the hook out that way. It pulled the plastic clip halfway out of the floor with it before they finally separated. Then I took the clip the rest of the way out and smoothed the edges with a nail file where it grips the hook ... not enough to really see any difference, but after putting it all back together it's yoinkable now the way you'd normally expect, with the plastic clip staying in the floor where it belongs.
    -Chap
  5. Mendel Leisk
    41,808
    Yeah, disclaimer: I've never done this. :oops:
  6. Marlon Estella
    Marlon Estella Junior Member
    Fontana, CA
    Just wondering if anyone had an answer for this?
    I'm planning on installing clazzio seat covers and i cant seem to find the hook or wire in the back seat of my two eco.
  7. MD Hel
    MD Hel Junior Member
    Louisiana
    Yes. There are two hooks, one on each side. If you gentle pull up on the front lip of the seat they are easy to locate. I just grab the seat on both sides of the clip and pull up. It should pop free.
  8. Marlon Estella
    Fontana, CA
    It should be the same on all 4th gens, but I'm feeling around underneath the backseat and i can't seem to find any hooks.
    Does anyone have this plastic "wall" that's covering the bottom of the seats?
  9. RRxing
    RRxing Senior Member
    2,553
    1,826
    NEPA
    Here's the Gen III removal procedure - May not be exactly the same for Gen IV
    Marlon Estella and Elt31987 like this.
  10. MD Hel
    Louisiana
    Here's a couple photo of the hook.
    Marlon Estella likes this.
  11. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    Bro how did you remove it just pull up? I want to install a cover I do Lyft sometimes, I don't the leather to be scratch by passenger's metal accessories.
