I have a question about Torque Pro I was wondering if anyone knew the answer to..
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Delane, May 8, 2017.
Tags:
  1. Delane
    Delane Junior Member
    Cetral Florida
    Ok, So i love torque pro and have learned about installing the PIDs Thanks to this thread and the people who have put the time into it.
    My question is, Can you download say a "setup"? Like for example, lets say one of you guys who have a 2nd gen that you set u p the way you like it to show a specific set of gauges etc, Can you then Export that to someone who can then use the same setup?
    I ask because there are so many things to which i can program, but i figured that people on the forum here and experts of Torque already spent the time to set up a general layout of some good gauges, like Voltage, engine temp, etc. Is there then a way to export a layout onto my Torque for example?
    Thanks so much in advance. I'm just trying to learn as i go. Anthony
    SFO likes this.
  2. Pantelis
    Pantelis Junior Member
    Greece
    Hello!
    Perhaps you know it already, but there is also hybrid assistant, only in Google Play.
    I have tried both, if there was Hybrid assistant two years ago, I would not have buyed Torque...
  3. Delane
    Cetral Florida
    I'll go check right now and see. Thanks!
    Pantelis likes this.
  4. Delane
    Cetral Florida
    Thanks for the recommendation of Hybrid assistant! Great app!
