Rattling Noise from the Heat Shield - Throw it away?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhman2006, May 13, 2017.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I've been hearing a little rattling noise from my car for a few days now. At the beginning I wasn't sure what the noise was, but today I jacked up the car, crawled underneath, and found out that the heat shield that goes above the middle section of the exhaust pipe has come loose. Does anyone know how important that heat shield is? Do I need to repair it or can I throw it away? One of my coworkers told me to throw it away ... apparently that's what he did with his.
    What do you folks think?
  2. Mendel Leisk
    40,698
    Never throw out anything. Just thank the automotive gods that it's at least still there. It does serve a purpose, best not to second guess it. Replacement cost for all these things is basically: take the most ridiculously exhorbitant cost you can dream up, then double it.
    Figure out why it's rattling. Maybe a missing bolt? More likely the bolt is still there, but the shield snagged on something and tore off the bolt, enlarging the hole? Get it raised, DIY if you can safely, and see what's going on.
    If it's a torn out hole, and the bolt is still there, at hardware stores you can pick up oversized washers: have larger outside diameter than usual, will span the torn hole. Bring in the bolt to check fit.
    douglasjre, ALS and Raytheeagle like this.
  3. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Left side of the shield is rusted out and just came off the bolt. The bolt is still there, but the piece that was holding onto the bolt got rusted and can't be hold onto by the bolt anymore.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,263
    15,512
    Bay Area, California
    2019 Prius Prime
    Temperatures in that area of the car are hot due to combustion. I would look for a salvage part if what remains will not work or cannot be cobbled together to work.
    IMO, replace the shield;).
    #4 Raytheeagle, May 13, 2017
  5. Mendel Leisk
    40,698
    If the tear is too big for over-sized washer, my next ploy would be a short piece of galvanized pipe hanger, again, just acting as a washer at the tear-out zone:
    Jack Maniaci, m.wynn, fuzzy1 and 2 others like this.
  6. Tande
    Tande Active Member
    529
    314
    Mich.
    FWIW....mine did the same thing at about 100,000 mi. .......I repaired it just as Mendel described in post #2.....
    Raytheeagle likes this.
  7. Kenny94945
    Kenny94945 Active Member
    843
    418
    Sausalito
    2016 Prius v wagon
    see post 4.
    I would attempt a repair with what ever product...hanger, washers, sheet metal, nuts and bolts
    Good luck.
  8. RRxing
    RRxing Senior Member
    2,533
    1,807
    NEPA
    This looks like it would work...
  9. ALS
    ALS Active Member
    590
    294
    Pittsburgh
    Yep $200 including labor. That is what I paid the dealer last month when mine came loose.
  10. goodwheelz
    goodwheelz Junior Member
    CT
    I tried a few solutions. The easiest was to put two pairs of 2 Harbor Freight steel cable ties through the hole and around the bracket above the heat shield. I positioned one band going through the whole and to the right and the other band going through the whole and to the left to provide a counter pressure on each side.
    Total Repair Cost: $6.99
  11. HammerGrips
    HammerGrips Junior Member
    Traverse City, MI
    Mine is now doing the same. I'm thinking I will just tear it off, assuming it's easier than reattachment. If you think about a Prius going down the road, there should be plenty of airflow. Sitting or slow traffic, the engine's not running.
  12. Mendel Leisk
    40,698
    Get some fender washers; make it last.
  13. Jack Maniaci
    Jack Maniaci Junior Member
    Chicago, IL
    Currently experiencing the same rattling; based on what I was able to see with ramps, this is the culprit bolt-hole-broken.jpg
    I'm guessing the bolt hole is too big / ripped open to go the purely oversized washers route.
    The galvanized pipe hanger seems like a good option, but I just wanted to clarify: are you saying to
    1) remove nut and bolt;
    2) loop a length of the pipe hanger around the top of the catalytic / exhaust assembly,
    3) cinch pipe hanger tight, and
    4) reattach nut and bolt, (perhaps with another big washer)?
    or am I misunderstanding the approach?
    **Also**: Are there are only two points of attachment for the heat shield? I didn't have time earlier to take more than a quick look with ramps, which were insufficient to see the entire shield / exhaust assembly. I know that the driver's side counterpart of the problem bolt hole is still securely attached, but could not really tell if there were more than two points of attachment.
    Thanks very much in advance!
  14. Tibor G Balogh
    Tibor G Balogh New Member
    Hello,
    I just repaired this, I used the bottoms of discarded aluminium cans, folded in the 1/8 in high thin skin after cutting them there and using the bottom as a washer, I drilled a hole in the middle, presed it all flat a bit in a vise and bolted it on in between the rusty washer-nut and above it the aluminium heat shield as if it was a big washer to hold everything in place...
    -tibor
    Jack Maniaci and Mendel Leisk like this.
  15. Jack Maniaci
    Chicago, IL
    Yes, I also ended up doing this. I also coated the can bottoms with rustoleum galvanizer to hopefully make them last longer.
    Six months later, the cans are still holding on tightly. About to repeat the can procedure for a different corroded bolt hole on the shield.
  16. douglasjre
    douglasjre Senior Member
    2,112
    703
    Null, NL
    1,400F w no shield. What do you want to destroy forst
