Just got Prius Center Caps in the mail.
Discussion in 'Gen 4 Prius Accessories and Modifications' started by TinyTim, May 16, 2017.
  1. TinyTim
    TinyTim Active Member
    387
    238
    Seattle
    A quick question for Prius owners who removed the plastic hub caps. I am heading to the local Toyota dealer to have my 5k service checkup. I am going to have them remove the hubcaps and go with the alloy wheels underneath when they rotate and juice the tires.
    For those who have installed their own center caps. Do these look like they will work, fit or are similar to the not so modestly priced Toyota certified center caps? They are 57mm caps.
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    They will work if they are the correct diameter. They just snap into the hole. They are -hub caps- , as in covering the hub. The others are -wheel covers-, as in covering the entire wheel. ;)
    I bought the "expensive" Toyota ones at the dealer from the GII - cost me a whole $50 Canadian for four, which today is about $30 US.
    RCO likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Diameter is not the only factor though. The groove in the Gen 4 wheel is set further inward than in the Gen 2/3 wheel, so the caps designed to fit the Gen 2/3 doesn't fit in the Gen 4 without some modification.
    RCO and Mendel Leisk like this.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I bought a set on eBay for about $26 which workperfectly! (see pics in my albums)
    RCO likes this.
  5. Mendel Leisk
    41,901
    ^ @David Beale : this is the case, nutty but true.
  6. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Except it's a wrong year model. Why are you posting in the Gen IV section anyways? Lol
    Nope..won't fit gen 4. Those are for older models.
  7. WilDavis
    2,493
    2,155
    49
    Well they fit my 2009 Gen II, oh! they don't fit yours? Well, all I can say is you seem to be mistaking me for someone who gives a shit! Have a nice life! ;)
    RCO likes this.
  8. Mendel Leisk
    41,901
    I've been frog-marched outa 4th Gen forums more than once, just a few chauvinists, my impression.
    I came right back tho, lol.
    #8 Mendel Leisk, May 16, 2017
    Andyprius1 and RCO like this.
  9. TinyTim
    387
    238
    Seattle
    Tiny Tim here again to check on my thread. My specific question was will these fit after I have the local dealership remove the hubcaps when they rotate and juice the tires? The nonsense posts such as gen 2 and gen 3 15" rims are different than Gen 4 or Gen 2 or Gen 3 owners posting in the Gen 4 forum.
    I will give it the old college try and see if they fit and keep you all updated on my endeavor.
    Andyprius1 likes this.
  10. Mendel Leisk
    41,901
    Can you pop one wheel off and try? Gen 4 for sure has shifted the groove on interior of wheel hub opening.
  11. tomstodola
    tomstodola Member
    129
    Ontario, California
    2019 Prius Prime
    Mine fit, but stick out about 1/4" Haven't fallen out, so I will stick with them for now.
    RCO likes this.
  12. xliderider
    8,140
    3,277
    Honolulu, HI
    The reason they are "sticking out" is that the tabs on the covers aren't able to drop into a groove on the inside of the hub. Perhaps removing the wire that reinforces the tabs from moving inward will allow the tabs to flex inward enough to allow the caps to be inserted further.
    RCO likes this.
  13. TinyTim
    387
    238
    Seattle
    Ok, back from the Toyota dealer. Got my complimentary Starbucks coffee and Coca Cola. Not a perfect fit but good enough. I do not want to risk breaking the center caps as suggested above by removing the wire to make the fit more snug. $8 worth of Chinese made plastic. I think it looks pretty good. For those who want a look at before and after.
  14. TinyTim
    387
    238
    Seattle
    After a short run on the freeway to get a car wash. I checked on the center caps and realized that the centrifugal force and probably laws of kinetic energy and inertia locked the center caps in. To get them of I would need a screw driver as the laws of physics worked well securing these new center caps.
  15. xliderider
    8,140
    3,277
    Honolulu, HI
    Or, remove the wheels and push them out from the other side. ;)
    krmcg and RCO like this.
  16. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Oh the joys of 20/20 hindsight! (n)
