Hv battery fan air intake filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jyoost, May 17, 2017.
  1. jyoost
    jyoost Junior Member
    US
    I ran across these at Home Depot for $5.00 enough to last a lifetime! Just pull up from bottom pull forward from top cut to size, cut notch out for post, snap back on. Voila no more plugged fan 1495034699151.jpg 1495034713281.jpg
    WilDavis, bisco and Aaron Vitolins like this.
  2. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    Aaron Vitolins likes this.
  3. Mendel Leisk
    38,732
    Yes and no: putting in a filter like that, and the denser the filter material the more the effect, makes it a permanently partially plugged filter. I guess the trick is finding a balance; I would err on the side of caution, ie: using a coarse, open-weave material is safer.
  4. srellim234
    1,198
    1,687
    Laughlin, Nevada
    That's part of the reason I'm using what I am. It is thin and very effective for dog and daughter hair but not so thick as to obstruct the air flow. I read the warnings from you and others here before I put in the first filter. The experienced people on this site are the greatest with helpful advice. (y)
    Mendel Leisk and Aaron Vitolins like this.
  5. Mendel Leisk
    38,732
    Yeah maybe, if it's designed for central heating vents, not much of a flow restriction. My school-of-thought now is to use household mosquito screen, has about 1/16" square openings. And check the actual fan every year or two.
  6. jyoost
    US
    Very unrestrictive material that is why I chose it. Cleaned all the dog hair out of fan and ducting about a month ago.
  7. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    Agree that denser filter that restricts airflow can cause the battery to overheat in the summer.
  8. bisco
    49,504
    i keep the dog on the roof, no fan issues.
    PriusGuy32 and jyoost like this.
  9. Mendel Leisk
    38,732
    We occasionally transport our Shiba Inu, who sheds from about January through May (I hope he's nearly done...). We don't put a lot of miles on the car, and he's not in the car for most of those miles, but he is occasionally, typically on the floor in the back seat, though he occasionally hops up on the seat. Been about 2 years since last I checked, and lately saw nothing even worth cleaning. Maybe depends on the type of hair (his is very short/downy), and to be fair there's not a lot of "Shiba miles" involved.
  10. jyoost
    US
    Short downy hair gets sucked right in. Goes straight to the squirrel cage and plugs the fins. Roof is the best option for no hair issues
