Battery discharges while parked all day at work (2014 Prius)
Discussion in 'Newbie Forum' started by Angela Marie Green, May 19, 2017.
  1. Angela Marie Green
    Angela Marie Green New Member
    28
    Maryland
    Anyone know why this is happening? Is power leaking somewhere? Thanks in advance.
    51,489
    normal. how many bars? it's just the surface charge wearing off, recorded by the computer and reported to the dash icon.
    RCO likes this.
  3. Angela Marie Green
    28
    Maryland
    2 and they were pink. It was alarming. :eek:
  4. bisco
    51,489
    no worries. the two that disappeared were pink, or the two left?
  5. Angela Marie Green
    28
    Maryland
    The 2 that were left. I've been able to charge it up fairly quickly with normal driving. I just thought there'd be a time when I won't be able to start it. I appreciate your responses.
    RCO likes this.
  6. bisco
    51,489
    it will never drop below two bars, but it will at times go to full bars. but these charge icons don't actually represent battery capacity. toyota has programmed the car so that the battery is never full and never empty. so the battery capacity is actually larger than needed or can be used, and this increases longevity.
    RCO likes this.
  7. Angela Marie Green
    28
    Maryland
    That makes sense. I really need to spend some time with that manual. Thank you, and enjoy your weekend.
    RCO and bisco like this.
  8. eman08
    eman08 Active Member
    360
    192
    US
    Just don't go through an automated car wash with two bars left and then put it in neutral. After that, you hang it up. It would have to be tolled to a Toyota dealer to be put on a grid charger.
  9. Angela Marie Green
    28
    Maryland
    Thats crazy. DVD says keyless fob can interfere with Mom's pacemaker. Lots to remember. Thanks
    RCO likes this.
  10. GeneG56
    GeneG56 New Member
    Williston, FL
    If you use a sun visor in your window make sure that you're not occasionally turning on one of the map reading lights overhead has happened to me twice
  11. Angela Marie Green
    28
    Maryland
    I also have been leaving my phone charger plugged in.
