Prius Prime frontal area
Discussion in 'Prime Main Forum (2017-2022)' started by Lee Jay, May 20, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Anyone (this means you, Bob) want to try to compute the frontal area of the Prime? I'm going to do so and wouldn't mind a few cross-checks.
    The ruler is 36" end-to-end near as I can measure. Heat distortion from the ground is going to make this a little challenging but we should be able to get close. Approximate distance is 215 feet, approximate equivalent focal length based on horizontal field of view is 1,400mm so this should have very little perspective distortion.
    HERE.
  2. Lee Jay
    5,850
    4,036
    Okay, I got 2.14m^2,
  3. bisco
    51,845
    are you thinking of adding a nose cone?
  4. Lee Jay
    5,850
    4,036
    Aerodynamic drag force = 1/2 * rho * A * Cd * V^2.
    We can compute rho from a local weather station (rho = P / R*T where R is 287.15, P is pressure in Pascals and T is absolute temperature).
    Cd is provided by Toyota.
    We can measure Velocity (V) in m/s.
    What we don't have is A - cross sectional area.
    Well, now we do.
  5. Prime Example
    Prime Example Junior Member
    58
    99
    Shenandoah Valley
    Wow, I didn't realize "full frontal" was even allowed on this site.
    hayden55 likes this.
  6. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    As long as the grill shutter is closed...
    Roof line to lower edge of front thing I can't remember what to call plus side mirrors and tires frontal area?
    Need an anemometer on a stick off the front unicorn style for the SAE rolldown test,
