So there is 3 pully for the gen 1? putting belt back on now
Discussion in 'Generation 1 Prius Discussion' started by nightmare66, May 19, 2017.
  1. nightmare66
    nightmare66 Junior Member
    24
    Kentucky
    2001 Prius
    I
    all intructions show 3 pullies?
  2. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    I believe there is 4 things the belt wraps around. alternator, a/c, crank, and tensioner
  3. ChapmanF
    17,484
    s/alternator/water pump/
  4. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
  5. Patrick Wong
    18,200
    6,493
    The 2G has an electric AC compressor, hence the serpentine belt only has to go around the crankshaft pulley, the engine coolant pump pulley and the tensioner pulley.
    The Classic has a regular pulley-driven AC compressor, hence the serpentine belt has to go around the above named three pulleys plus the AC compressor pulley, per the diagram in post #4 above.
