Which cleaner for the plastic gauge cover
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by rowekmr, May 18, 2017.
  1. rowekmr
    rowekmr New Member
    Chicago, IL
    2016 Prius c
    Which solvent/cleaner is safe to use on the clear plastic that covers the gauge cluster? Mines is dusty with smudges from previous owner.
  2. Mendel Leisk
    41,826
    "solvent/cleaner" sounds a little ominous. Best bet, maybe something designed for cleaning eye glasses? And: spray it on a cloth, not directly on the display.
    I get these small spray bottles of solution from my optometrist. Fine for coated plastic lens, and I use it on camera lens filters and the like.
    Google:
    Alcohol-free Anti-Reflective eyeglass cleaner
    Something like windex is probably fine too. Again: spray onto cloth, not directly.
    #2 Mendel Leisk, May 19, 2017
  3. Fred_H
    Fred_H Misoversimplifier
    560
    485
    28
    Germany
    I use exclusively dihydrogen monoxide in combination with a clean microfiber cloth.
    Dihydrogen monoxide is a strong solvent, but completely safe for all plastics.
    Edit: No, this is not a joke.
    #3 Fred_H, May 21, 2017
    Sean Nelson and Raytheeagle like this.
  4. Mendel Leisk
    41,826
    I'd most likely start with a soft cloth, soaked in warm water with a shot of dish wash liquid, then well rung out.
    #4 Mendel Leisk, May 21, 2017
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I prefer to use industrial strength HIJKLMNO.
  6. Mendel Leisk
    41,826
    Oh, I just figured out what dihydrogen monoxide is: clever clogs :p
  7. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    when I come off the oil drilling rig after a long hard 12 hr shift, I jump right in my prius and smear greasy sludge all over the interior. and I just leave it there. It no longer looks like a sissy car.
    djdawn likes this.
  8. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    This is what I use. Works like a charm. :)
  9. Got2bHam
    Got2bHam Member
    155
    51
    Missouri
    I use Pledge Mulit-Surface on the dash and gauge cover. Applied using a microfiber towel. Honestly you're not going to hurt it unless you use an orbital sander or a paint stripper. Worst case scenario you're cleaner streaks, Windex, vinegar and water solution, etc. will be good options too.
  10. coyotesafteru
    coyotesafteru Junior Member
    What about Pee ?
  11. coyotesafteru
    No solvent or cleaner is good for clear plastic. Gently blowing off the dust with compressed air and following with a damp microfiber cloth is the best. The more you rub, the more the clear plastic gets scratched and hazy.
