A/F Control test
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jgurley, May 20, 2017.
  1. jgurley
    jgurley Junior Member
    42
    17
    I've got a DTC P0138, and have already replaced the downstream sensor (aftermarket, I admit)
    Using Techstream, when I run the "A/F Control" test, I get the expected values:
    -12.5% Upstream = 3.9v, Downstream = .13v
    +12.5% Upstream = 2.5v Downstream = .99v
    which matches the graph in the manual nicely. However,
    0% Upstream = 3.1v Downstream =.87v
    At neutral injection, I'd expect both sensors to be "in the middle", although I realize it's a high gain function.
    As the data shows, the Upstream sensor is in the middle, but the downstream is still showing "rich".
    The freeze data from the DTC also shows a high value (.76) for the downstream sensor.
    It appears that either the downstream sensor is crappy, or maybe my catalytic convertor is shot due to my oil burning 215K miles? Opinions?
  2. 05PreeUs
    05PreeUs Senior Member
    1,097
    564
    MSP
    The voltage function from one HEGO sensor manufacturer to another are not exactly the same. One would think that if it shows as a compatible part for the OEM, it would be essentially the same voltage function, but differences do exist.
    The upstream HEGO is a "Wide Band" and should return ~2.5V at 14.7:1 AFR (Bosch). The downstream is a narrow band, plain old O2 sensor and fully warm, engine at 3000 RPM should have a voltage of about 0.4v-0.5v STEADY. If it is jumpy between 0.2v and 0.9v that does indicate a failed CAT or major exhaust leak (unlikely).
    Yes, oil consumption, if going thru the CAT is a major cause of premature failure. However, that assumes mostly unburned oil from failed piston rings or valve guide seals and not consumed oil from a failed PCV valve.
  3. jgurley
    42
    17
    I replaced the PCV valve a few weeks ago, and the old one seemed functional. I didn't check the downstream sensor except under the A/F Control conditions, where it's successfully followed the fuel injection ratio, except to see the "steady" value of .87v at idle. I'll try higher RPM tomorrow morning. My Techstream connection seems to crash a lot (driver problem or OS?) so getting a plot of the voltage is a painful process. Maybe I'll hook up an oscilloscope.
    I'll change out the sensor for a genuine Toyota before I replace the CAT.
  4. jgurley
    42
    17
    Here's a couple of more data points:
    1) The DTC freeze data showed an O2 sensor of .78v
    I put the thing into Inspection Mode, warmed up, and found
    2) At idle, the sensor is sitting at .83v with a little variation to as far at .78 and .85
    3) At 2500rpm, the sensor sits at the same vales as in #2
    4) As it returns to idle, the sensor drops to .11 or .13 momentarily, then returns to the .83v
    Any clue what this is trying to tell me?
  5. valde3
    valde3 Senior Member
    2,002
    748
    Finland
    You did connect the new sensor with the connector to vehicle wire harness and not just butt connector or solder it to wires of old sensor?
    #5 valde3, May 21, 2017
  6. jgurley
    42
    17
    It was a plug compatible sensor. Supposedly a Denso, but I think it was marked otherwise. I'll check the connector, but I checked it when I replaced the sensor (and used some contact cleaner). I have another sensor on the way, this time a Toyota part.
    Oddly, I got a different, more detailed, message via email that is shown above this post.
  7. 05PreeUs
    1,097
    564
    MSP
    The real question is what is the upstream sensor reading?
    If they BOTH indicate rich, then you most likely do have a rich condition. If the upstream is normal, then either the downstream is lazy, or the CAT is compromised.
    Toyota and Subaru are VERY, VERY sensitive to CAT efficiency and will set the dreaded P0420 DTC for even the smallest amount of efficiency loss. If you are not seeing that DTC, the CAT is good.
  8. jgurley
    42
    17
    The original post has the A/F voltage - looks right to me. Haven't gotten any codes besides P0138.
  9. jgurley
    42
    17
    Checked the connector and ground connections, and all are per the manual.
    OK, here's the latest data. Engine was warmed up and in "inspection mode"
    1000rpm a/f=3.22v o2=.76v
    1500rpm a/f=3.40v o2=.80v
    2500rpm a/f=3.32v o2=.82v
    voltages varied within .05 of those voltages over samples
    Using the "active test" for the A/F Injection,
    0% injection
    same values as above
    -12.5% injection (manual says to expect a/f greater than 3.35v, o2 less than 0.4v)
    1000rpm a/f=3.85v o2=.09v
    1500rpm a/f=3.78v o2=.11v
    2500rpm a/f=3.75v 02=.09v
    +12.5% injection (manual says to expect a/f less than 3.0v, o2 greater than .53v)
    1000rpm a/f=2.43v o2=.95v
    1500rpm a/f=1.66v o2=.95v
    2500rpm a/f=2.27v 02=.95v
    It looks to me like both sensors are reacting properly, except that the O2 sensor is "offset" for what it considers rich. I think the o2 sensor switches at about -2% injection, but the software decided to crash right then.
  10. valde3
    2,002
    748
    Finland
    Check the rear oxygen sensor voltage with the multimeter. If the voltage is not the same as what ECU reports then you have some problem with ECU (not necessary bad ECU). Maybe do the same for front air fuel ratio sensor because how the system is set up. As the sensors work opposite way that will multiply a small problem.
    If those are correct then you bad front air fuel ratio sensor or bad rear oxygen sensor or bad wiring.
  11. jgurley
    42
    17
    Is replacing the A/F sensor as big a pain as the manual indicates? Although I'll do the multimeter test today, and wait for my new O2 sensor before diving into the A/F, I'm inclined to believe it's the forward sensor since my mileage had deteriorated before I quit driving the car as if it was actually running rich.
  12. jgurley
    42
    17
    The multimeter test shows the reading is accurate.
    Does this theory make sense? :
    The A/F sensor would adjust for oil burning, but the burned oil would accumulate in the CAT. The oil sitting in the CAT would "rich-en" the exhaust as it passes through, so the O2 sensor would see "rich", meaning the CAT is the problem.
    I think replacing the CAT (49 state style) is cheaper and way easier than replacing the A/F Sensor. I'll do neither until I get the third O2 sensor installed and checked.
  13. jgurley
    42
    17
    My third O2 (Toyota branded) sensor works exactly like the original and the non-Toyota replacement. Sits at about 0.8v unless I modify the injection using an Active Test. The new one will go through it's linear point (flip from >.55 to <.04) at about -4% injection.
    I'm inclined to think the car is actually running rich, since my MPG had gotten worse over the last year. Replacing the A/F sensor seems like the obvious next step, but I'm missing the manual pages that explain the needed disassembly, so I'm almost ready to throw in the towel.
    Open to suggestions!
  14. 05PreeUs
    1,097
    564
    MSP
    Not having done this on our G2 yet, not exactly sure where it is located, but do not recall seeing it in the manifold when I did the coolant pump for the engine. Most likely in the exhaust pipe after the header connection and before the cat; that will be well under the car.
    Typically, they are "plug-n-play": loosen, unplug, unscrew, install, connect and tq - you are done.
  15. jgurley
    42
    17
    The "parts locator" in the manuals are very frustrating to find actual parts. I think it's on the manifold, since you can replace the whole exhaust system from below, while you need to remove and/or drain a bunch of stuff to get to it. I found the instructions online (along with a few indications that there are any shortcuts).
    What I'm really looking for is advice about whether it's the A/F Sensor or the CAT...I guess I could let the dealer give me an estimate, but I think they'd end up shot-gunning parts too.
  16. valde3
    2,002
    748
    Finland
    It really can’t be the catalytic converter as bad catalytic converter would reduce the voltage of rear o2 sensor, not increase it. So what is left is wiring (which you have already partially checked), ECU (which is very unlikely), or front air fuel ratio sensor.
  17. jgurley
    42
    17
    I have to make double sure that the O2 heater is working, then it's either sell the car as-is or dig into it first.
    Techstream doesn't offer sensor heater current, although SnapOn's analyzer does (according to Youtube). Guess I have to find a spot where the wire has enough slack to clamp meter it...probably right at the ECU.
  18. jgurley
    42
    17
    So oil burning couldn't damage the CAT to create the symptom? I'm skeptical about the A/F Sensor being bad just because it responds as expected and an offset in it's sensor reading seems like an unlikely failure mode.
  19. 05PreeUs
    1,097
    564
    MSP
    Oil burning that goes thru the cylinder is nowhere near as bad as oil that is not combusted from worn rings or valve seal/guide issues.
    All of the ECM inputs, including the MAF sensor, are very low current so even a seemingly small resistance in the sensor circuit can bias the signal seen by the ECM. Since you KNOW the voltage seen internally by the ECM, I would suggest you compare that to a reading AT the sensor with a high quality meter.
    Also, it is possible that there is a grounding issue causing either a sensor or ECM bias in the signals.
  20. jgurley
    42
    17
    My O2 sensor voltage is not getting lost, at least not between the connector and the ECU. Measuring the A/F is problematic, since I don't think you can get to the connector without removing things.
    I don't know here my oil is going - no blue smoke, but oily exhaust pipe. My oil level was suddenly low at about 120K miles, and I think it did some damage. Whether it's leaking through the rings or valve guides, it's getting burned in any case, isn't it?
