2003 inverter pump replacement, can I use 2004 up pump
Discussion in 'Generation 1 Prius Discussion' started by John B., May 17, 2017.
  1. John B.
    John B. Junior Member
    2001 Prius
    I
    It looks like the inverter pump on my 2003 Prius has failed, and I am not having a lot of luck finding a replacement that is affordable. Can I use one for a 2004 or newer model? I am thinking a pump is a pump for this purpose, as long as it will fit in the hole and I can tie it down.
  2. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
  3. Patrick Wong
    18,200
    6,500
    The correct pump costs $114 plus shipping here:
    Water Pump - Toyota (G9020-47022)
    I think it is a particularly bad idea to use a 2G inverter coolant pump because that pump was the subject of a recall, hence a used pump that you can find on eBay probably is a reject with questionable service life remaining.
  4. dabard051
    dabard051 Tinkerer-in-Charge
    258
    97
    Rochester, NY USA
    2002 Prius
    I vote for the correct part. The cost of incorrect operation of a substitute is, as Patrick pointed out, VERY high, and I personally would not want to do that job twice just to save a few bucks. Also, spend the extra coin for genuine Toyota coolant for topping off that system. The OEM stuff lasted what, 15 years, so Toyota obviously knew what they're doing...
  5. Brian in Tucson
    981
    453
    Tucson AZ
    2003 Prius
    OEM Coolant is available from your local dealer or from Amazon.
