Push AC button and nothing happens. Push the Auto button and it comes on.
Discussion in 'Prius c Technical Discussion' started by tnt4him, May 22, 2017.
  1. tnt4him
    tnt4him Junior Member
    53
    Beaverton Oregon
    Finally some hot weather. My wife comes home and says the AC is not working in the Prius. So I go out to the garage and turn the car on. Push the AC button and nothing happens. I push the auto button and it turns on then off (the green lights) Then I push and hold the auto button and the AC comes on but goes off if I let go. I repeat this several times until the car gets nice and cold. Then I let go of the auto button and it stays on. I cycle through on off auto and everything appears to be working but for awhile AC did not work but auto did. Is it the control panel or a sensor? Any ideas? 2012 prius c 28k/
    52,351
    did you turn the fan on before pressing a/c? is the temp set to 'low'?
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi tnt4him,
    Many of us have this problem too. The Fan [OFF] button gets stuck when you press it down sometimes. If you pressed the button repeatedly, it should get back to normal operation.
    Vincent
    #3 vincent1449p, May 23, 2017
    AliIzad likes this.
  4. AliIzad
    AliIzad Member
    170
    72
    Southern California
    Yes! I had the same issue before I finally figured out the OFF button was stuck.
  5. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I just had the same thing happen to me a few days ago. You just have to push the "OFF" button while wiggling your fingertip around to free the button from being tucked under the plastic that surrounds it. A bit annoying, but trivial to fix once you figure it out.
  6. tnt4him
    53
    Beaverton Oregon
    Thanks everyone for your responses. The off button, son of a gun. Its always a relief to know why. Thanks a million.
  7. bisco
    52,351
    if the off button is stuck, why does auto work?
  8. Sean Nelson
    421
    182
    When you push the AUTO button the green light comes on, but then it goes back out again almost immediately.
  9. everdave
    everdave New Member
    Earth
    2015 Prius c
    I always turn the ac off before I shut down and when I start I always hit fan up button and the ac comes on. I think that is normal.
  10. Arsal
    Arsal New Member
    Karachi
    Its not working o mean in my prius ac button green light is not turning on so suggest me some better
  11. Oldwolf
    Oldwolf Prius Enthusiast
    826
    110
    NC
    2016 Prius v wagon
    My OFF button sticks occasionally, as well. I guess there is no fix but replace the switch?
    Looks like the button assembly pops off, maybe some cleaning is needed.
  12. frenzee
    frenzee Member
    95
    73
    Costa Mesa, CA
    I had this happen too, especially on hot days. Plastic-safe lubricant will solve or at least minimze the problem. I recommend Deoxit Fader F-Series, which is specifically made for plastic-to-plastic contact surfaces. Teflon or silicone based dry lubricant will also work. Don't spray directly onto the OFF switch. Use a Q-tip or toothpick. Don't use WD-40 or anything with solvents or oils in it. That will make it worse.
  13. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    It has to be a defective or poor quality switch/button combo
    Im sure toyota is well aware of it.
    On my 2012c I remember it happening and buying my 2014c I new of the problem
    and it pretty much happened from the start.
    Never got either of the switch/buttons dirty,
    Since I am aware I just know to look for it now.
  14. Leadfoot J. McCoalroller
    8,134
    7,641
    Pennsylvania
    2018 Prius c
    Thanks! I haven’t had this problem yet, nor had I run across this product. I’m a big fan of Caig’s other Deoxit products, really saved my bacon a number of times.
    Engineering & manufacturing quality buttons that fit and work for decades in the conditions of a car cabin is difficult and expensive. This is part of why Tesla skipped it and went straight to a touchscreen.
    dig4dirt likes this.
  15. Adam Foldi
    Adam Foldi Junior Member
    Providence, RI
    hey all, commenting on this old thread. I have a related but different situation. Just bought a used 2010 Prius. Green AC light is always on. Doesn't matter if I press Auto, or manually adjust the fan, temperate (all the way up to max and down to lo) and mode(which vents the air blows from). If I press the AC button it doesn't respond, the light just stays on no matter what. I'm not used to Prius (it's my first) so I wasn't sure what to listen for with the compressor kicking on or off. In a regular car you can listen for the AC compressor clutch kicking on and off. I heard nothing, but it definitely blows ice cold air when I put it to the lowest temperature setting while the car is parked in a heated garage. It blew cold air without the ICE kicking on for the first 10 seconds or so, then it turned on. So the AC is working I think!? But is the compressor silent?
    I saw some folks talking about stuck buttons, but the button doesn't appear to feel sticky or anything. I pressed it light, pressed it hard, even banged on it a bit... nothing. Any wise advice out there? Was thinking of buying a replacement HVAC control board and switching it out to see if that will work.
    Cheers,
    Adam
  16. ChapmanF
    18,503
    The compressor doesn't have a clutch that clacks like you're used to from other cars, but it also isn't silent when it's running. Sounds a bit like a distant Cessna.
    It's variable-speed too, so you can hear it more easily under heavy cooling loads than under light conditions.
  17. Vijay Jayaram
    Vijay Jayaram Junior Member
    Hi Adam, I also bought a used 2010 Prius and have the same issue you describe. Did you figure out how to how to fix the issue. Thanks, Vijay
  18. Pri3C
    Pri3C Active Member
    183
    131
    Midwest
    2014 Prius c
    The AC light is always on on in Auto mode with my Prius C. But if I set the temp to 70 and it’s 30 outside, it’s going to give me heat. And it’s 90 outside, it’s going to give me AC.
    My light and AC can be manually switched off out of auto mode, though, so this feedback likely isn’t directly related to your issue. But yeah, the main thing to confirm is that the AC is working properly, which you should be able to feel + hear the compressor at idle in EV mode.
  19. Vijay Jayaram
    Agree, AC is always ON in AUTO mode. But my issue was that AC would be ON when AUTO was OFF. AC would go OFF only when I turn the FAN OFF, but I would like to run the fan without the AC ON. Anyway I went and disconnected the battery for some time and connected again and controller started functioning normally, lets see how long this will work. I am guessing the controller IC might have gone bad, one can easily replace the circuit board. I ordered for a replacement unit from ebay for $25, next time it malfunctions I will try to replace the board and see how it goes.
    Pri3C likes this.
