Spark Plugs - Dutch Owners manual says 90k km
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gatoman39, May 25, 2017.
  1. gatoman39
    gatoman39 Junior Member
    Netherlands
    I have a Dutch Prius 3. The owners manual says to change the spark plugs at 90,000 km (54k miles). This makes no sense to me. How can a American version go 100k. They have to be the same mechanically, what accounts for the difference in maintenance requirements between USA and the Netherlands?
  2. Patrick Wong
    18,200
    6,500
    Actually the US maintenance schedule is 120K miles except extended to 150K miles in California.
    My guess is that the region maintenance schedules are partly based upon local regulations and marketing considerations.
    gatoman39 likes this.
  3. Former Member 68813
    3,524
    983
    US
  4. StarCaller
    StarCaller Senior Member
    1,277
    729
    Cedar Crest, NM, USA
  5. gatoman39
    Netherlands
    I think this is a good explanation. The driving and weather conditions are more similar to the US, than different. Considering what a pain in the arse it is to remove the plugs on the Gen 3, I think I will go with the US schedule. Thank you Patrick!
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I consistently hear that European oil is superior to US oil. What if European gasoline is inferior to US gas?
  7. Mendel Leisk
    41,334
    I agree: a couple of inches more clearance and I think you would be able to remove the spark plugs without all this nonsense. If you haven't found it, you really should watch @NutzAboutBolts video on how to access the spark plugs, here:
    Nutz About Bolts Prius Maintenance Videos | PriusChat
    (video 13)
    There's another issue with 3rd gens, which tends to rear it's head around 100,000~150,000 miles, the EGR cooler, valve, pipe and intake manifold can clog. Having the cowl and wipers off for spark plug replacement, that might also be an opportune time to look at EGR. And, a little early, but removal of the EGR cooler necessitates coolant line disconnect, so coolant change?
    It just cascades...
  8. Former Member 68813
    3,524
    983
    US
    I don't think it's excessive burder to do that maintenance every 100,000 miles or so.
  9. Mendel Leisk
    41,334
    It sure opens things up. Our previous Civic was similar: for spark plugs or valve clearance check, or getting at the engine block coolant drain bolt, you needed to take off similar cowl. At least wipers and motors could stay in place.
  10. Siward
    Siward Active Member
    314
    128
    Toronto
    If the manual says 90,000km or 60,000 miles, I am guessing it is possible there is platinum spark plugs in there. I would suggest swapping them out as the schedule says until you know what type of spark plugs they are.
    The American/Canadian schedule assumes there is stock Iridium tipped spark plugs that would last 190,000km or 120,000 miles.
  11. Mendel Leisk
    41,334
    Spark plug is spec' on owner's manual?
  12. gatoman39
    Netherlands
    I asked the dealer today about this. The part numbers they gave me are the same as the N American version. They are Iridium Denso plugs Toyota Part#:
    90919-01253
    I asked them why there is a discrepancy between maintenance schedule between a American and Dutch car. They said they had no idea. But they said that they often see Gen 3 Prius with 200k miles that have never had their plugs replaced and the cars work without problem.
  13. Mendel Leisk
    41,334
    This is an excerpt from Canadian 2014 maintenance guide, for all Toyota vehicles with iridium plugs:
    (Translates roughly to 120K miles or 12 years)
  14. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    While they don't need to be -replaced- very often, I think it might be wise to remove them and put anti-seize grease on the threads then reinstall them every 50,000 km or so. So when you DO need to replace them you can actually get them out!
    On Pearl (Gen II) I didn't have to remove the cowl or wipers when I put anti-seize on them, though it was called for in the instructions. It was tight but I managed. Is the Gen III even tighter?
  15. Mendel Leisk
    41,334
    Yeah, the coil can be unbolted and pulled up a bit, but hits the cowl before it's high enough to be angled up-and-out of the spark plug well. It's really a bonehead design shortcoming. @NutzAboutBolts video is invaluable for how to pull off the cowl. The instruction is buried in the Repair Manual, but the video is a lot easier to find and follow.
    A little data: third gen spark plug torque with dry threads is 15 ft/lb. I guestimated 12~13 ft/lb when I inspected and reinstalled them with a very sparing coating of anti-seize. I used a 9/16" spark plug socket, and I believe the kosher is actually 14 mm, which is slightly more snug.
    Funny: someone following the Repair Manual instruction "to the letter" used a torque wrench when reinstalling the diminutive 10 mm (socket size) coil hold-down bolts. Except, he misread inch/pounds as foot/pounds: put his hefty torque wrench on the poor thing, and snapped the head right off.
