How to clean underneath/outside the cup holder?
Discussion in 'Gen 3 Prius Main Forum' started by nanoxnano, May 26, 2017.
  1. nanoxnano
    nanoxnano Junior Member
    26
    Anyone know how to remove this? I want to be able to clean the gunk found underneath. A toothbrush isn't work too well.
    52,847
  3. JC91006
    JC91006 Senior Member
    16,936
    8,647
    Compressed air
  4. Mendel Leisk
    42,343
    Leaf blowers at dawn!
    CNYhybrid likes this.
  5. CNYhybrid
    CNYhybrid Member
    158
    83
    Liverpool, New York
  6. ChapmanF
    19,019
    Start with the cupholder lid closed, just as in the picture. Turn one hand palm up, and with the longest one or two fingers, push the top of that lid inward slightly, just enough to get those two fingers past it and under the lower edge of the darker, triangular piece that goes around the shifter. Push upward with those fingers until that shifter trim pops out. Lift it out around the rest of its edges. You don't have to take it completely out or unplug the connectors that go to it; just tip it and set it a bit to the left.
    Now pull up the cup holder (and the whole right trim edge running up beside the glove box, which all comes with.
    Wipe up the crumbs.
    Pop the cupholder back into place. Pop the shifter trim back into place on top of it. It's faster to do than to read. :)
    -Chap
  7. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Ignore it.
    nursingninja and CNYhybrid like this.
  8. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    Exactly. No tools required. It's very easy to remove those two trim pieces.
  9. qdllc
    qdllc Senior Member
    1,377
    400
    I'd use an old t-shirt (clean). A layer or two of cloth would work like heavy floss.
  10. Mendel Leisk
    42,343
    Or a small brush, together with a vacuum. That's my technique in a lot of the corners, like the seat hold-down bolt recesses, around the gas pedal, and so on.
