EZ Oil Drain Valve Installation (EZ-103) Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jbusta, May 28, 2017.
  1. jbusta
    jbusta Junior Member
    33
    Hey everyone,
    I just purchased an EZ drain valve. Do you know if we should use the supplied Viton "O-ring" that comes with the valve, or would we be better off buying a new oil drain gasket/washer? (if so, Copper or aluminum?)
    And second, when tightening the valve, is it better to go by the product's recommendation of hand-tighten and then 1/2 turn or should we go by Toyota's proper torque of 28 ft-lb.?
    Thanks in advance.
  2. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I installed a Fumoto F103 valve on our Prius hatchback. I don't remember obsessing over the gasket and tightening torque as much as you. ;)
    IIRC, I used a coated aluminum washer and tightened it "enough".
    Keep in mind that the valve body is brass, which is softer than the oem steel drain bolt, so I wouldn't tighten it to the oem specification, which might strip the softer brass threads on the valve.
  3. johnjohnchu
    johnjohnchu Active Member
    212
    105
    I had utilized Fumoto valve to ease oil draining on my Prius for many years. However it had been hit a few times due to Prius' low clearance and the actual oil drain location. I always worried that the valve can be accidentally opened. Now I am back to using the oem drain bolt which I think it is much safer.
  4. Mendel Leisk
    41,898
    I would follow tap manufacturers torque spec, and use the washer they supplied. I would never use a tap tho, for same reason as previous poster.
  5. Bill Lohman
    Bill Lohman Junior Member
    Stockton, CA
    2014 Prius c
    I agree with Mendel. Use the recommended torquing with the associated parts. As for using a metallic washer instead of the o ring... I'd be inclined to move back to the Toyota spec. 28 lb/ft wont strip the brass threads unless you're removing/reinstalling the valve a lot...which kind of defeats the point.
