Home charging with ChargePoint and range added calculations
Discussion in 'Prime Main Forum (2017-2022)' started by Dmitriy Sokol, Feb 1, 2017.
  1. Cave Arnold
    Cave Arnold Member
    64
    60
    Lehigh Valley, PA
    I also created a second request for an enhancement to the ChargePoint app and website based on my experience this week charging and seeing that the miles added estimate by ChargePoint was way off.
    I have noticed a disparity in the ChargePoint EV miles per charge and the Toyota Prime EV miles per charge. In order to correct the discrepancy I first compared the numbers over the charge period then computed the slope of each line and divided the slopes to come up with a simple multiplier to approximate the Toyota Prius Prime's numbers which I know to be correct. I am attaching the spreadsheet with these calculations.
    I would like to request an enhancement where a factor like this can be entered by the ChargePoint user for each vehicle charged and this will be used when that vehicle is charged to convert the ChargePoint miles estimate to a better approximate of the vehicle itself. This will allow a better estimate and you will not need to make any major changes to the existing UI, only accept and store a single conversion factor along with each vehicle registered. It is also a fairly straight forward change to make as opposed to my second thought for consideration below.
    Later if you want to be more precise you could allow those ChargePoint users that want a more accurate evolving factor to enter the actual mileage their car reports for each session and then use this to calculate the factor to correct all past and future mileage estimates.
    I think the improved accuracy would appeal to a large section of the ChargePoint community.
    ArcPrime likes this.
  2. Swauger
    Swauger Member
    37
    34
    PA
    This would be a pain but you could always just flip the breaker switch everytime you leave. This would stop anyone from using it since there's no juice going to it.
    alexcue likes this.
  3. Team ChargePoint
    Team ChargePoint Active Member
    171
    106
    Campbell, CA
    @scm2000 you'll find more opinions on home charging options in this thread, too!
    scm2000 likes this.
