Another Bluetooth issue
Discussion in 'Prius v Audio and Electronics' started by Sar710, May 26, 2017.
  1. Sar710
    Sar710 New Member
    2014 Prius v wagon
    I have a 2014 Prius V 3. I've had it about 2 years. Just recently the bluetooth has started turning off after about a minute of the car being started. It can not be my phone because to troubleshoot I turn the bluetooth off on my phone. Start car, go to Bluetooth set up. Bluetooth on is checked. After a few minutes, it turns off and I am unable to turn it back on. I took it to dealer, and they claimed that I needed an update (for $115). Then they claimed that they could not get the update to install so my unit must be faulty. Came home and my 18 year was able to download and install the update in less than 10 minutes. Great! But I still have the Bluetooth issue.
    I realize that there are several posts concerning this, but none of them mention that it turns off even when a phone is not paired. Obviously, my dealer is not much help. It's beyond frustrating.
  2. Priifan
    Priifan Member
    93
    143
    Cary, NC
    This sounds quite frustrating, just like our music shutting off and receiving the message" looks like you are using another device to play music'" on our iPhones. It can happen two seconds into a song or not at all. The iPhones's software is updated when the notices come out. I have put some music CD's in the car for when this happens because who wants to drive three hours with no music? But this also happens at home sometimes, so I think it is an iPhone issue rather than a Prius problem. Does anyone else get this message when their iPhone music quits playing in their Prius? Aaargh!
  3. caphesua46
    caphesua46 New Member
    VN
    i used bluetooth win 10, so ok
  4. dr.Berkes Attila
    dr.Berkes Attila New Member
    Hungary
  5. dr.Berkes Attila
    Hungary
    I stumbled upon this mysterious " Prius bluetooth off " issue today and this solved the problem right away.
    ( 2012. Prius Plug-in
    Samsung Galaxy Note 8 )
    The solution comes from SID000.
    She found it at an android forum.
    Bluetooth
    Paired devices
    Settings
    Disable text
    Thanks for helping each other.
