Anyone know if/where i could get a spare fuse box cover?
Discussion in 'Prius c Accessories and Modifications' started by Bryce Husserl, May 28, 2017.
  1. Bryce Husserl
    Bryce Husserl Member
    30
    27
    2016 Prius c
    Im thinking about adding usb ports and want them on their own fuse. However for me to do this without messing with the preexisting cables i would run them out the side of the fuse box, meaning i would need to trim or file down the fuse box cap for the wires to run through. Im looking for a spare cover in case this all goes wrong
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  3. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Wrecking yard?
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    I left mine off, it's in the glove box. No one will see your open fuse box unless they lay in the driver's footwell on their back.
  5. Bryce Husserl
    30
    27
    2016 Prius c
    True, just wanted it to look nice incase need to get rid of it in the future
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    I found two fuse blocks under the hood and one in the driver's footwell, did anyone ever figure out which one he needed?
  7. xliderider
    8,140
    3,277
    Honolulu, HI
    I had the understanding that it was the one in the driver's footwell.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  9. Mendel Leisk
    41,925
  10. NyQuil
    NyQuil Junior Member
    30
    2016 Prius c
    you can add a fuse or two to your internal fuse box and hook up to the matching pin. I just did this, though i used an existing fuse for the "moon roof" (i dont have one but the fuse is still there)
  11. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    You could also use an inline fuse.
