Red Triangular Warning Light
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Annie Lou, Jun 5, 2017.
  1. Annie Lou
    Annie Lou New Member
    Michigan
    I happy 2007 Prius which I purchased two years ago. One year later I had to please second battery. About six months later that one went bad and I had to replace it again. A couple of days ago The red triangular warning light flashed on and off within a couple of seconds while I was driving. Today it is happened twice again. I ran the diagnostic found that the battery is running at about 13.8. Is it possible that it's a bad battery again? Why does the light come on and then go off again so quickly?
  2. JC91006
    JC91006 Senior Member
    16,496
    8,406
    You should check your engine oil level, most likely low on oil
  3. Annie Lou
    Michigan
    I own a 2007 Prius which I purchased two years ago. One year later I had to replace the second battery. About six months later that one went bad and I had to replace it again. A couple of days ago The red triangular warning light flashed on and off within a couple of seconds while I was driving. Today it is happened twice again. I ran the diagnostic found that the battery is running at about 13.8. Is it possible that it's a bad battery again? Why does the light come on and then go off again so quickly?
  4. bisco
    49,720
    welcome!
    are these all the 12 volt battery? if so, it sounds like something is daring it. but you can't test it with the car in ready.
