Proposal to charge in my condo garage
Discussion in 'Prime Plug-in Charging' started by MNdriver, Jun 5, 2017.
  1. MNdriver
    MNdriver Senior Member
    549
    577
    i have an electrician coming by this week to discuss options for charging in my garage - I'll use this to create a proposal for the condo board.
    I'd like to run some ideas past you experienced folks. I want to propose an option whereby I can reimburse the association for juice used.
    One idea is to put a normal, but metered, 110 outlet near my stall. I've found something called EKM meters which look like they'd work to monitor my usage.
    Another option, much more expensive I think, would entail running 240 a long distance to my stall, and installing something like a JuiceBox Smart EVSE which I believe can produce summaries of my usage.
    Any thoughts on these or other options? I haven't seen either the meter or the EVSE in person so I hope I'm understanding their usage correctly.
  2. Prodigyplace
    12,526
    11,747
    Central Virginia
    I believe @bwilson4web has used a JuiceBox.
    He should be along shortly to comment.
    Prius from Dad likes this.
  3. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I guess it would depend on your charging needs. If like me, you can charge overnight, then the 110 option seems right. If you need fast charging then the 240 option would work better.
    HPrimeAdvanced likes this.
  4. MNdriver
    549
    577
    Do you think both options would work to document my usage for the purpose of reimbursing the association?
  5. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Save money. Use 110 and charge overnight. If you need to go then use gas. Gas is cheap now and hell...it is a hybrid.
  6. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    I guess any documentation may satisfy the association. I use 6.3 kWh per "full" charge to figure my cost. If you can document your usage from your outlet, then it only matters which option you need. Good luck(y)
  7. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Might help if there were others in your complex who could benefit from this upgrade. Safety in #s.
    MNdriver and Prius from Dad like this.
  8. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Could be helpful if you commit in your proposal to a fixed deposit that will be renewed each time it is zeroed so your account is always in the 'green'. May sometime help to cross a potential psychological barrier.
    Trollbait likes this.
  9. MNdriver
    549
    577
    Thanks, giora, that's a good suggestion. There are some owners who are very focused on each expenditure, and I want to make very sure that they are comfortable that my car isn't going to cost them money.
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    And it is highly likely that at least one of "those people" don't really understand electricity and will be opposed to the options that you listed.
    The best solution might be: Have a separate meter installed just for this one outlet and the bill sent to you.
    IF......your meter is accessible, maybe a branch circuit could be run off of your existing meter.
    Some people will just automatically be opposed to anything that they don't fully understand........and don't want to listen to reason......and won't back down. An "end run" is often best.
  11. Prodigyplace
    12,526
    11,747
    Central Virginia
    If you are paying the bill, you would need to secure the connection against unauthorized use by anybody and everybody.
  12. Sam Spade
    2,036
    1,023
    2017 Prius c
    That part is cheap and easy.......to the point of being trivial.
  13. MNdriver
    549
    577
    OMG, you've met my neighbors?!
    Re: unauthorized use, I have scouted out locking outlet covers at Menards. I need to carry my cable inside to make sure it fits in the 'box' but I think it will work. I was less worried about unauthorized use than would like to be lazy and keep my cable plugged in without having to worry about it walking away.
  14. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Third Option:
    EKM meters also come in 220
    amazon.com/Electric-Meter-100A-Volt-3-Wire/dp/B00GMZRXE8
    So have you electrician select a 220 outlet type and mount it with the meter and use a 220 ESVE cable with the same plug. NEMA 6-20 is common, but there are others.
    amazon.com/Electric-Vehicle-Charger-Portable-EVSE/dp/B0714JB9Q3
    That way you can use the 220 charger at other locations with that plug or 110 at a slower speed.
  15. MNdriver
    549
    577
    I was running my idea (the 110/EKM meter version) by a coworker and he said this:
    "If you are tapping into a line which is shared elsewhere the other current may have to be taken into account. For example, if you draw 12 Amps and are ultimately hooked to a 15A breaker that is shared with a garage door opener, the breaker might trip if anyone opens the garage while you are charging."
    This doesn't strike me as a worry for charging a Prime overnight, even in a shared garage.
    I will be asking the electrician about the 240 option, but the only current 240 source is quite a distance from my car, and in a concrete block room where the trash compacter is. I think it's going to be cost prohibitive to go that route, but I will ask.
  16. bisco
    51,832
    he is correct, you should have a dedicated circuit. therwise, you and whoever else is on it may have trouble, which will leave a bad taste in the boards mouth.
    the only way to know would be to know what else is, and/or will be on the circuit. are the breakers too far away?
  17. MNdriver
    549
    577
    yes, unfortunately my parking spot is as far from the breakers as you can get!
    Shoot, I hope this is going to be doable.
  18. bisco
    51,832
    at least you have the 8 amp option.
  19. Prodigyplace
    12,526
    11,747
    Central Virginia
    Any other PHEV owners that may be interested in splitting the cost?
  20. MNdriver
    549
    577
    No, I'm alone in the ICEy wilderness.
    bisco, what do you mean by the 8 amp option? (sorry if my question is naive - I'll still a newbie at this charging stuff.)
