Replace Cabin Air Filter
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Rangerdavid, Jan 24, 2017.
  1. Prodigyplace
    12,617
    11,804
    Central Virginia
    I got confused too since i thought the filter i the center of the photo looked like the cabin filter. My apologies.
  2. Mendel Leisk
    41,749
    You see one, you seen 'em all. (y)
    RCO and Prodigyplace like this.
  3. krmcg
    2,592
    2,392
    Whittier, CA
    Thanks!
  4. Prodigyplace
    12,617
    11,804
    Central Virginia
    is your 2016 a carbon filter?
  5. Prodigyplace
    12,617
    11,804
    Central Virginia
    IMG_0355.JPG IMG_0358.JPG IMG_0355.JPG My original filter is a different color. I really doubt it got that dirty since October. There are no part numbers on either filter.
    The engine filter number matches what I ordered.
    ETP, ePWR and RCO like this.
  6. randomwalk101
    randomwalk101 DYI'er
    532
    271
    texas
    Bought some carbon filter to replace stock carbin AC filter. The replacement's cleat is not same direction as stock like OP said. There is a raised plastic piece inside the holder that prevents the replacement filter from coming in. This piece has no structural purpose other than just that. Toyota must have put it there to force user to buy their brand which cost 10x more.
    Solution? Dremmel that's POS off. Now it'll fit oem filter or aftermarket.
    Btw stock filter is not carbon so if it looks black it's dirty. Lol.
    grape808 and RCO like this.
  7. Roy N
    Roy N Junior Member
    Los Angeles
    Four Touring
    ETP likes this.
  8. priusgto
    priusgto Active Member
    194
    231
    Northern Arizona
    ETP likes this.
  9. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    Dealer Linear Thought Process: Is Customer Car in for Free/Warranty Service? Yes. Sell them Something. End.
  10. grape808
    grape808 Active Member
    150
    153
    Hawaii
    I bought these on amazon (EPAuto CP285) and they didn't fit because of that plastic piece. I didn't actually need to replace my original filter yet so I gave the filters to a friend with a Corolla.
    Thanks, I may give those a try. Based on cleat direction it probably fits even with that plastic insert that kept the above filter from fitting.
  11. priusgto
    194
    231
    Northern Arizona
    I received mine Friday and can confirm also that the TYC800208C fits exactly like the OEM filter.
    eric1234, grape808 and RCO like this.
  12. ETP
    2,802
    1,170
    Auburdale FL
  13. ETP
    2,802
    1,170
    Auburdale FL
    Sounds like they are bilking customers. Might want to change dealers.
  14. Mendel Leisk
    41,749
    There was a way, actually, a reason for the early change: it turned out a rodent was getting at OP's filter.
  15. Prodigyplace
    12,617
    11,804
    Central Virginia
    ETP likes this.
  16. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    Filthy! That's the only way to describe it after 11 or 12 months in my 2016 Prius. I bought the OEM Toyota cabin filter for 15 bucks, online somewhere. (Cheaper than my lunch!) No hesitation whatsoever in buying new filters once a year. And getting the oil change at the same time. It makes me laugh, guys spend 30 grand on a Prius, and then don't want to spend 5 minutes putting in a new clean $15 filter.
  17. raspy
    raspy Senior Member
    438
    699
    London, UK
    I just ordered a Toyota 'enhanced' cabin filter for my Gen 4. Earlier someone said it's more expensive than the standard one.
    However, when I called the dealer in London to order one, he said it's 34 pounds for the standard one, and 22 pounds for the enhanced one. I figured I'd give it a try since I spend a lot of time in traffic behind horrible diesel vehicles.
    RCO and CoastRider like this.
  18. raspy
    raspy Senior Member
    438
    699
    London, UK
    Just replaced my cabin filter that was white at new. After 11 months and 8,500 miles in London traffic, it's pretty dirty. I put in an enhanced filter as Toyota reckon it traps 25% more pollutants than the regular filter. 1497255726948.jpg
  19. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    Thanks for the picture. Those filters seem to do a good job. Mine looks the same after 1 year. Time for a new one.
    RCO, Prodigyplace and raspy like this.
  20. Backwoodzcustomz15
    53
    53
    Lancaster, pa
    Three Touring
    I know this is an old thread but here is my step by step video how to replace the cabin air filter. I hope this is helpful.
    RCO likes this.
