A/C defaults to recirculate?
Discussion in 'Prime Main Forum (2017-2022)' started by UMR-280Z, Jun 7, 2017.
  1. UMR-280Z
    UMR-280Z New Member
    New Mexico
    I've been the proud owner of a Prime Premium for about a month now. I've put on 1050 mi. but only used ~1/4 tank of gas since I've owned it. I'm impressed.
    Does anyone know how to make the car not default to recirculate for the HVAC every time the car is turned off and restarted when using AUTO mode for A/C? I'd like to have fresh air in the cabin without having to mess with the climate settings every time I get in the car. Thanks in advance!
  2. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    Search ALL forums for the term "recirc" and it will bring up several previous threads on the topic. I did not read all, but in what I just saw, there was no definitive solution to re-program the A/C system to do what you want.
  3. Lee Jay
    Lee Jay Senior Member
    5,850
    4,033
    Westminster, Colorado
    Recirc does bring in fresh air. It's not 100% recirc, it's more like 80%.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    No that is not an option that can be changed.
    Push ONE button. Really inconvenient. ?????
    ePWR likes this.
  5. markabele
    5,084
    1,782
    Nebraska
    Guessing there is a nicer way to say it.
    Prius from Dad, Since2002 and sonomac like this.
  6. Mendel Leisk
    40,974
    Is there a way, if the system's off, to turn it back on with whatever settings you had previously? I think not, but not sure.
    With our previous Honda, if you pushed the fan speed up or down, it'd "wake it up" with previous settings restored.
    IIRC with our 3rd gen doing that just puts it in auto mode with fan speed locked, not that useful.
  7. Lee Jay
    5,850
    4,033
    I think that's exactly what it does.
  8. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    No, 2 buttons.
    The problem for circulating most of the air within the cabin is that I have already started to smell rancid air from the vent. After some researching, it looks to me that the human perspiration will condense inside the A/C ducts and cause rancid smell. Fresh air from the outside can prevent it.
    No way. I've tried that. The computer always recalculate to recirculate the air to save a drop or two gasoline.
    #8 CaliforniaPrius, Jun 7, 2017
  9. Sam Spade
    2,036
    1,023
    2017 Prius c
    "Nice" is over-rated.
    Mine has ONE button that controls re-circulation.
    Push-ON; push-off.
    What other button do you think is necessary ??
    Well I'll be. Learn something new every day. :eek:
    What self appointed Internet expert came up with that earth shattering research ??
    I think it is MUCH more likely to be mold spores growing on the evaporator and drain tray, which stays moist almost all the time.
    Using fresh air will help some but not much.
    Turning the A/C OFF and turning the recirc OFF and leaving the vent fan ON before turning the car off will help a lot more; but to be effective that has to be done maybe 5 to 10 minutes before stopping.......and it gets downright uncomfortable in that time.
    #9 Sam Spade, Jun 7, 2017
    ePWR and mmmodem like this.
  10. ePWR
    ePWR Member
    131
    137
    PRIUSchat
    My car is just the opposite. Is the Prime different from the regular Prius that most of us drive? In my gas-guzzling old fashion 2016 model, I like using the Recirc button so as to not be sucking in so much dust & dirt. I leave it on constantly.
    But every time I start the car, it reverts back to the "open vents" mode. Using "auto" doesn't change that. So I have to waste a whole 1.5 seconds, and reach over and hit the Recirc button. 1.5 SECONDS that I will never get back! GONE.
  11. CaliforniaPrius
    313
    201
    Alameda, California
    "Climate" then the recirculating icon
  12. markabele
    5,084
    1,782
    Nebraska
    Interesting theory. That's a lonely despairing road.
    Since2002 and KrPtNk like this.
  13. Tideland Prius
    16,499
    If you leave ECO Heat/Cool in "normal" mode instead of ECO, it'll be more likely to use FRESH AIR.
    RECIRC helps because you're cooling/warming air that you've already cooled/warmed - it's a way to get the cabin cooler/warmer faster (in normal mode) or to require less power to maintain the temperature (eco mode).
  14. Mendel Leisk
    40,974
    So, there is no "on with previous settings" button. Your sole recourse if the system's off, is to push "Auto", and accordingly dismiss any and all overrides.
    Seems a little odd, and Toyota's not alone in this, that such a fundamental option is not available. Something for @Prius Team ?
    Again, with Honda's, at least our last, if the system's off and you push fan speed up (or down, I believe), it turns things on with your previous settings. Even this seems quirky, a sort of obscure Easter Egg function.
  15. Sam Spade
    2,036
    1,023
    2017 Prius c
    Oops. Sorry. Forgot about the "touch screen" controls.
    But those icons are really close together, right ? ;)
    No it isn't.
    A really lot of people fully understand that everything doesn't have to be sugar coated.
    And not everybody has to feel like "a winner" all the time either.
    Just out of curiosity, how old are you ?
    My bet is under 35.
    In general, you should NOT use recirc when heat is required.
    That can often make the windows fog over.......really bad and really quickly.
    #15 Sam Spade, Jun 7, 2017
    Prius Maximus likes this.
  16. Lee Jay
    5,850
    4,033
    That's true, but in Colorado it's only humid enough for that to happen about 5% of the time I need heat. The rest of the time, recirc provides enough fresh air to keep the windows clear.
  17. Sam Spade
    2,036
    1,023
    2017 Prius c
    Sure but that 5% can be really annoying.
    I learned that lesson the hard way when the temp was about 10 F and the outside of the windows were heavily frosted over.
    Started the car, turned the blower on high, set it to heat and recirc.
    Took the scraper and attacked the windows.
    By the time that was done, ALL of the inside windows were now frosted over........except tiny little patches by the defroster vents.
    :mad:
  18. Prius Maximus
    Prius Maximus Senior Member
    955
    809
    Northeastern IL
    Auto AC defaults to recirc to bring the temp down quickly when it's first turned on. My problem with recirc is it gets stuffy in the car really fast with so little fresh air. I only use recirc for short bursts - like when I'm getting coal-rolled or a truck is spewing heavy black diesel exhaust. But then I never use Auto AC and I'm also in an old outdated 2014 regular Prius....
    What irritates me is the AC turning on when I use the super cabin pollen filtration. After I hunt around to find that button on that infernal flying butt-ress, I have to then search for the AC button. Very distracting when driving... I put little self-adhesive rubber bumpers on each button to make them easier to find without looking. But as I get older, I forget which button is which. :coffee:
  19. Lee Jay
    5,850
    4,033
    And yet, I had it on recirc for my entire 1,450 mile trip with four people in the car last week, without noticing any air quality problems.
  20. Prius Maximus
    955
    809
    Northeastern IL
    Hmmm, wonder if something isn't quite right in one of our cars. After a few minutes on recirc, I notice a distinct increase in breathing difficulty. Like High CO2 or low O2. and the humidity jumps up too. But maybe it's just me, I can't be in the house when the wife lights one of those smelly candles. Airwick freshener? Worse than waterboarding.
