I Don't Think This Is COOL
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by The Phoenix, Jun 5, 2017.
  1. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    I wanted to post here to see if anyone that's been under the hood of a Prius or maybe any car for that matter could give me some perspective. From what I think I know there is black...like a burnt area in the corner of what I believe is the A/C condenser. It was like that when I bought it in Feb 2016. Last summer my A/C seemed to work ok. This year I'm not sure, the air blows cool not super cold. But the few times I used it this year the cabin temperature was way hot. I wonder if it's only a small leak and can be temporarily fixed with a recharge of Freon. The car is a 2008 with 237,000 miles so I don't want to sink a lot of $$ into but I drive a lot and don't want to go without A/C I included a picture as well 20170521_095302.jpg
  2. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Can try a can of AC Pro. Might be low on freon.
  3. bisco
    52,337
    just be careful, the a'c is high voltage, and requires special oil.
    Montgomery, valde3 and jzchen like this.
  4. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    Ooh. Forgot about that possibility. It's not PAG?
  5. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Just a guess, but it looks like there was a leak and the oil in the AC refrigerant attracted a lot of road grime. Adding AC refrigerant will probably just leak out again.
    valde3 and robibb like this.
  6. Mendel Leisk
    41,850
    Regarding cylindrical gizmo on the right side called, the cooler/dryer: maybe at the bottom junction of that component and condenser (AC radiator) there's a leak?
    Attachment is from third gen, not sure how relevant. Personally, I would bring it into dealership, at least get their diagnosis and quote.
    #6 Mendel Leisk, Jun 5, 2017
  7. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    Thank you for the feedback so far. I agree there might have been a leak and hoping a slow one so more refrigerant wouldn't leak out immediately. I also like the idea that it might be the connection between the dryer and the condenser. I am probably going to have it looked at but I want to get all the information out there I can before I do
    robibb and Mendel Leisk like this.
  8. RRxing
    RRxing Senior Member
    2,553
    1,827
    NEPA
    ND-11. See Mendel's attachment.
  9. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    So yesterday I had it in to a repair shop and had the A/C checked. Since I have some zip ties and such holding some of my underbody bumper parts together I asked them to be careful dropping the bumper. They checked the A/C without removing the bumper so no one saw the black on the front of the condenser. They told me no leaks were found but the system was low. They filled me with one pound of freon for $15 and $43.45 for labor $8 for supplies which I'm not sure what that could be. So for $70 I'm back to cold air and everything seems to be fine. As long as it's working I'm fine. Thanks for the help. Is there any opinion about if this is a good and reasonable fix?
  10. Mendel Leisk
    41,850
    Wait and see.
    Montgomery likes this.
  11. The Phoenix
    The Phoenix Member
    217
    84
    Fredonia WI
    Four Touring
    That's exactly what I thought too. Thanks
  12. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Holy crap dude go buy some ac coil cleaner and hose it down and clean up that condenser. It's the beginning of some rust or Rot there. Clean it up.
  13. jm98
    jm98 Member
    155
    37
    17
    Four Touring
    Someone suggested in this forum to clean and spray a specific external seal that works with aluminum.
  14. DonDNH
    1,711
    655
    Nashua, NH
    Four Touring
    I hope they used the correct refrigerant for the Prius. It should be R134a with ND-11 oil. Using regular freon with other oil can and usually will in time damage the compressor.
  15. milkman44
    milkman44 Active Member
    591
    386
    Ky
  16. Mendel Leisk
    41,850
    I think as long as the the charge had no oil you'll be ok. IIRC the Repair Manual says if the system's been run with the wrong oil, then you have to replace pretty much everything. It might be in the attachments. Think good thoughts.
