What is the Hybrid battery lifetime?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Matthew Burger, Jun 6, 2017.
  1. Matthew Burger
    Matthew Burger New Member
    Bowie, MD
    I have 2005 and 2010 Priuses. Both have about 135k miles on them. The 2005 needs a new battery. Is 135k a reasonable # of miles to get out of the battery? Is there any way to predict how long the battery will last on the 2010 Prius?
    Thanks.
  2. Kevin_Denver
    Kevin_Denver Active Member
    581
    425
    Denver, CO
    There's 4 main factors that affect battery life:
    1. Number and depth of charge-discharge cycles
    2. Age
    3. Storage temperatures, the higher the worse; garaged Prii and those in cooler climets have longer battery life. I suspect with enough data you could show that white Prii have longer battery lives than black...
    4. Battery maintenance - how long the battery ever went without being used, etc. The car's battery will last the longest if driven daily.
    135k is low, but your batteries are old; considering the batteries were probably made in 2004, they're now 13 years old. There are a high number of failures around the 12-15 year mark reported here, mostly 04-06s, due to age (and mileage to a lesser degree). However, those who drive 50k/year can often push 300k out of a battery over 6 years, so I wouldn't say there's a given number; it's mostly a combination of age and mileage.
  3. bisco
    52,341
    they are probably designed to get most of them somewhere past warranty, which is 10/150 in carb states. as mentioned above, a number of factors can effect their life both negatively, and positively.
    some experts here believe that gen 3battery is not as robust as gen 2. only time will tell.
  4. Priusyipee
    Priusyipee Active Member
    354
    269
    Upstate New York
    I have over 300,000 miles on my '05 Prius with the original hybrid battery still going...
  5. eman08
    eman08 Active Member
    360
    192
    US
    Milage has relatively nothing to do with battery degradation. Its the age. Some times these batteries can last up to 12 years or more as it really depends. I have 175k miles on my 2009 Prius with very little degradation based on my TechStream diagnostic computer. IMG_20170603_205001812_HDR.jpg
    salyavin likes this.
  6. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    Our previous Prius (the 2006) had the battery fail at 9 1/2 years and 125,000 miles. It seems early but it was obvious from the paint job that the car was not garaged and kept out in the southern California sun. Most likely it degraded due to the heat.
  7. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    If you need a new battery autobeyours.com has rebuilt batteries for about $800 the last time I checked.
  8. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    There is total of 168 cells in the HV battery pack.
    How long is a battery pack is useful people often look at remaining capacity and also the ability the pack to hold voltage under load.
  9. Peter Chicarielli
    Peter Chicarielli Junior Member
    New Jersey
    How can you check the current state of your hybrid batteries?
  10. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Need techstream software to do it a high level but Dr Prius a phone app used with a bluetooth dongle or wifi like Carista.
    I do not own a Dr Prius app but many posters do so I will let them weigh in. You can use the search foums tab up top and search
    Mini VCI
    Techstream
    VXDIAG
    DR Prius
    Torque
    Peter Chicarielli likes this.
