Prius C 2 light settings
Discussion in 'Prius c Main Forum' started by Justin Hargrove, Jun 15, 2017.
  1. Justin Hargrove
    Justin Hargrove New Member
    Hesperia ca
    2015 Prius c
    So there is 4 settings with the headlights: off, Daytime running lights, Daytime running lights with parking lights, headlights and high beams. My question is does anyone use the daytime running lights with the parking lights at night? its just barely dimmer than the regular headlights setting and was wondering if its more efficient as in taking up lest electricity?
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    I have a Canadian model Prius C on which the daytime running lights come on whenever the car is moving - there's no switch to turn them off. If the DRLs on your car are the same as mine, they're actually a dimmer version of the high beam headlights. (I've always thought that they do this by running the two lights in series from 12V power so that each light gets only 6V, but I don't know if that's actually true).
    As such, it's not a good idea to use them at night because they're shining directly into the eyes of oncoming drivers. They're dimmer than full high beams, but at night they're still brighter to oncoming drivers than properly adjusted low beam lights.
    Even if that wasn't the case, the amount of electricity saved is a drop in the bucket compared to the other systems and gas used for propulsion, and it really isn't worth obsessing over IMHO.
    Justin Hargrove likes this.
  3. Justin Hargrove
    Hesperia ca
    2015 Prius c
    Interesting! Here I thought I was doing everyone a favor by running the daytime lights. Thanks for the heads up
  4. Sean Nelson
    421
    182
    You're certainly doing them a favour by running them in the daytime! At nighttime I believe that low beams are preferable.
  5. ericmj
    ericmj New Member
    Los Angeles
    2017 Prius c
    Very confused about this too. I'm coming from a 1996 Avalon which I had the lights to the topmost setting.
    The 17 Prius C has extremely blue white lights that are intensely bright... I was told by the dealer guy to have them on the topmost setting as well when driving at night, but I was a little hesitant to do so because they are so bright.
    Because of that I've figured out that the tail light setting (the symbol with two wedge shapes side by side with three bars emanating from either side IMG_9681.JPG ) are basically the head lights but dimmer. Also they shut off automatically when you open your door after shutting off the vehicle, which the headlights do not. So I'm using the parking light setting (next to topmost) for now, which are still extremely bright.
  6. Sean Nelson
    421
    182
    "Head lights but dimmer" are the daytime running lights. If you park at night in front of a wall so that you can see the patterns cast by your headlights, you'll see that the daytime running lights, although dimmer, project light ahead of you in a pattern that reaches higher than if you turn on the lights all the way so that the low beams are on. The low beam lights have a very sharp cutoff so that light doesn't project upward into the eyes of oncoming drivers. The daytime running lights, although dimmer, will be shining into the eyes of oncoming drivers. Not a problem during the day, but not so good at night, IMHO.
  7. ericmj
    ericmj New Member
    Los Angeles
    2017 Prius c
    Good to know. I'll keep that in mind
