Last time you used fuel???
Discussion in 'Prime Main Forum (2017-2022)' started by huskers, Jun 21, 2017.
  1. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    Last time my gas engine came on was May 31st. So 21 days ago.
  2. dalcon95
    dalcon95 Senior Member
    512
    653
    Easley, South Carolina
    April 22
    #1 in Easley,SC
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I take it you're not over in the Sandhills or maybe 30 miles from Bridgeport or something. :D
  4. huskers
    2,544
    2,487
    Nebraska
    Wow, I bow to the master.
  5. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    Stale gas in your tank could create problems. Gasoline has a shelf life and this issue worries me about the Prius Prime. Do you use a fuel stabilizer to keep the fuel from going bad?
    wastoooo likes this.
  6. huskers
    2,544
    2,487
    Nebraska
    No, just drive the car.
    dalcon95 likes this.
  7. dalcon95
    512
    653
    I put pure gas and fuel stabilizer in on February 26th, which is when I last filled up. I am currently at 404 miles to empty on that tank of gas.
    #1 in Easley,SC
    jtg61 and Prius from Dad like this.
  8. Krzysiek_KTA
    Krzysiek_KTA Active Member
    159
    125
    Houston
    just quick one: what is the shel life of the ordinary fuel in the tank?
    . I used gas after 2+ months sitting in the tank and did not experienced any issues.
    last time I used gas was on May 29th and re-filled the gas.
  9. dalcon95
    512
    653
    Going by the owners manual, Toyota says fill 1/2 tank every 12 months. We will see how that goes.
    #1 in Easley,SC
    Prius from Dad likes this.
  10. Krzysiek_KTA
    159
    125
    Houston
    no worries then. I will use charge mode to burn some stalled gas if necessary. Thanks for info
  11. bisco
    52,286
    my engine came on this morning.:( on the plus side, i filled up 4/27 and my ev/hv ratio is 950/100 miles.
    pip o/m says a full take every 6 months, so that's a huge improvement for prime!(y)
  12. Bob Comer
    Bob Comer Active Member
    708
    460
    South Carolina low country
    Just got my Prime yesterday and I used gas to get out of the garage this morning. :)
    I'll never be even close to you guys in non-gas usage, my commute is further than the Prime's EV range, so I'll use gas every day. But that's okay, I'll still get better than anyone else's gas mileage around here!
  13. crewdog
    crewdog Acting Ensign Prius Prime
    493
    388
    Woodstock, GA
    1st and only fillup so far was 3/14/17.
    Got 2 bars left now, last time ice came on was 6/10, with that day's mileage at 782.9 mpg
  14. markabele
    5,084
    1,782
    Nebraska
    Don't forget to count your electric usage in your energy costs.
  15. dalcon95
    512
    653
    I have spend $22 (1 tank of gas) and $84 ($14 per month in electricity) for a total of $106 for over 6 months since December 3rd. I have driven 5800 miles since new. Cheap operational costs!
    #1 in Easley,SC
  16. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The last time I filled up was in Goodland, Kansas on May 31st. Since then I drove home to the Denver, Colorado metro area, have driven all around the city averaging about 40 miles a day, took a nearly 300 mile round trip over two days to Pueblo, Colorado, and I still have about a quarter of a tank left.
  17. jtg61
    jtg61 Member
    46
    43
    Ocala FL
    I work in outdoor power tools at Lowe's and we see a common problem with gasoline power tools having trouble with stale gasoline and 10% ethanol gasoline causing issues. We sell a product called Star Tron
    "Diesel fuel and gasoline are not formulated to be stored for more than 90 days. After this period of time, they begin to oxidize, forming sludge, varnish, gum and other harmful deposits. The ability of the fuel to burn properly is diminished as chemical components start to break down."
  18. davidtm
    davidtm Member
    180
    TJ'ville
    So, I had to . . .
    $0.018/mi - less than 2 cents!
    Son of Gloin and dalcon95 like this.
  19. Prodigyplace
    12,628
    11,808
    Central Virginia
    Most outdoor power tools should be using ethanol-free gas anyway. Ethanol-free gas stations in the U.S. and Canada
    I believe 90 days is for the common E10. I think pure gas is good for 6 months.
  20. bisco
    52,286
    my toro lawn mower say 30 days gas storage. maybe it's the size of the ports? i would think toyota has a good handle on this.
    6 months in my pip and no problem, but 6 months in small power equipment, and it won't start.
    Prodigyplace likes this.
