ICE On in EV Mode!
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Jun 22, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    You're awesome!
    No road trips for you, eh?
    That would be pretty much the case for me except a road trip to Houston (~500 miles to, at, and back) and another to Pedernales Falls State Park (108 miles).
    iPhone ? Pro
    priuscatprimeguy likes this.
    51,542
    not if it records it as ev, because the engine is only warming up, and not providing motive power.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    @bisco, you need to copy the previous post you are referring to, because I have no idea what you're talking about:confused:
  4. bisco
    51,542
    you're not the only one.:rolleyes:
  5. priuscatprimeguy
    2,730
    2,640
    if you are referring to the ECO Dashboard and it's record of EV miles, well then if the ICE kicks in your EV miles would be zero at that point hence the car is not going anywhere, just warming up:D
  6. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    Toyota leaves it WIDE open why the ICE might come on in EV mode ... manual pg87 ...
    mr88cet likes this.
  7. mr88cet
    2,313
    1,335
    Austin, TX
    OK, that's good.
    However, what was curious in this case was that all of the dashboard indicators I could see concurred that it was in EV mode (i.e. It did not cancel EV mode), but the drive-system monitor still showed a red energy-flow arrow out of the engine.
