Tire Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by nyprius, Jun 26, 2006.
  1. Mendel Leisk
    38,724
    Eug (post #537), if you're still on the planet: I would have called it good with the plug repair.
  2. ETP
    2,801
    1,170
    Auburdale FL
    Anyone have a 2009 Touring. I may need to get another set and wondered what was best for MPG.
  3. Primetime15
    Primetime15 New Member
    Amarillo, TX
    Hey, that's a lot of technical stufff. Please, I just spent a day researching tires. I need help! 2015 Prius 3. Simply, what is the best all weather tire? I live in Amarillo, usually hot dry summers, and unpredictable winters other than we can count on occasional black ice. Safety, quiet, MPG are tops with me. Thanks, everyone--I simply cannot read everything here about tires. I am setting my decision deadline for the third week of July (2017) :)
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    you need to be in the gen 3 forums, but you can't go wrong with Michelin. continental and yokohama are good too. for wet roads, general altimax have always been highly rated. low rolling resistance tires are a must if you want mpg, but bridgestones got lousy traction, so that brings us back to Michelin or continental
    Primetime15 likes this.
  5. ETP
    2,801
    1,170
    Auburdale FL
    Bridgestone is the best. Ecopia EP422 Plus that comes on many new Prius. Most Walmart's carry these in stock.
    Bridgestone Ecopia EP422 PLUS 195/65R15 91H - Walmart.com
    Bridgestone Ecopia EP422 Plus (H- or V-Speed Rated) | 195/65R15
    Tire Search Results
    #545 ETP, Jun 23, 2017
  6. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    I'm looking for some new tyres tomorrow think I'm going for 185 55 r16 will these be ok for the car
  7. Primetime15
    Amarillo, TX
  8. Primetime15
    Amarillo, TX
  9. Primetime15
    Amarillo, TX
    I was in Gen 3 Forum, then someone advised a follow this thread. Thank you for responding.
  10. 69shovlhed
    2,170
    748
    Delaware
    I see, said the blind man. tire rack did some good testing, and there was a Michelin LRR tire which beat all the others. I will most likely get Michelins when these ecopias wear out because traction isn't very good.
  11. dolj
    dolj Senior Member
    7,652
    3,866
    Wellington, New Zealand
    I thought the UK spec was 195/55R16 tyres? If you are looking to go to the smaller width tyre, you will need to choose a 185/60R16 to minimise the discrepancy in diameter. The 60 ratio profile is closer then the 55, being that that is the ratio of width to height. In any case make sure the tyre you get is rated A for fuel efficiency and A/B for wet grip.
    The information in this thread will not be too applicable to you as the EU tyre situation is quite different from the US.
    #551 dolj, Jun 24, 2017
    iron-icman likes this.
  12. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Thanks for that in the end I ended up getting x4 195 55 16 Mitchelin ones part worn for £80 which I thinks is a great deal
  13. dolj
    dolj Senior Member
    7,652
    3,866
    That is a good deal. What specific Michelins did you get?
  14. iron-icman
    iron-icman Member
    130
    43
    Leeds UK
    ----UK----
    Think they are some sort of eco ones on the wording of the tyres pretty happy however haven't checked them this morning ha
