Rear wiper blade - too short??
Discussion in 'Prius c Accessories and Modifications' started by GabriolaGuy, Jul 15, 2016.
  1. GabriolaGuy
    GabriolaGuy Junior Member
    44
    Gabriola, BC, Canada
    2016 Prius c
    Technology
    I think the rear wiper blade is a bit too short to clean a decent size area of the window.
    I'm sure you could place a longer, by about 2"-4" blade there, but what would fit?
    Has anyone done this "mod"?
  2. ShaAnn
    ShaAnn Member
    94
    42
    2014 Prius c
    I have no idea....it hasn't rained in so long here in Calif that I haven't even used my rear wiper yet.....hope there is a fix out there
    TC400 and GabriolaGuy like this.
  3. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    I was wondering this as well. It appears one could get a slightly longer blade and it "should" work
  4. GabriolaGuy
    44
    2016 Prius c
    Technology
    I suspect it would and I have not checked the blade myself. I was hoping some one here had determined what needed to be done and explained how it worked, so now I guess I'm going to have to do it myself,
  5. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I tried a 10" blade on there (8" is stock) but it hits the spoiler.
    Then I got the bigger JDM spoiler, which is slightly different. Tried it again. Hit that too.
  6. GabriolaGuy
    44
    2016 Prius c
    Technology
    I haven't looked closely at it, is it difficult or unique in its mounting or similar to how the front ones remove?
  7. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    It's a plastic blade - similar to other rear wipers on newer vehicles. You have to snap the cover off the pivot of the arm where the nut is, then you can lift the blade, and you tilt it until it snaps off. Check out a Youtube video first because the force required to do both of these things feels like it's going to break the plastic.
    GabriolaGuy likes this.
  8. GabriolaGuy
    44
    2016 Prius c
    Technology
    It appears with the original blade holder, the stiffener, not the actual squeegee part, has ends on it to prevent the actual rubber to move and that would make it difficult to increase blade length unless it was possible to fine a similar stiffener, only a bit longer.
    I guess I just have to live with it for the time being. :-(
  9. Ronan
    Ronan Junior Member
    28
    Denver Co
    2014 Prius c
    No 9in wiper blades out there?
  10. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Replacing wiper blades on the prius is no different than any other car. Just go to Auto Zone or O'rileys and look up what it takes and buy the blades. Installed like any other blade. Don't just buy the rubber inserts buy the whole blade. You can go 1 in longer or shorter on the blades. I recommend the Rain X blades.
    #10 lar.smith42, Aug 5, 2016
    GabriolaGuy and Ronan like this.
  11. Bill Lohman
    Bill Lohman Junior Member
    Stockton, CA
    2014 Prius c
    Seriously lar.smith42? Anyhow... to address your actual question, I think you were on the right track with the 10" arm replacement. And I'm reasonably confident that you can't just change to a longer blade on the same arm - even if it physically could be done, you'd have no tension on the outer end of the blade and you'd get no better/more clearing of the window.
    I live in California too, and I'm quite frustrated at the really small swath of the factory wiper...and it looked like a 10" would be optimal (barring the aforementioned colliding with the spoiler). But I think I've also seen retrofit wiper arms that have multiple pivot points that you can select which one to use at the time of installation (essentially giving you like a 1/4"-1/2" shift in the wiper position, instead of being forced to pivot in the exact center). Since this has not only been an ongoing frustration for me, but now I see others are thinking along the same lines, I'm going to look into the wiper arms I described. I'll post any results here.
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    This has been tried on here earlier. They were able to put a 10" blade on the OEM arm. His blade didn't hit the spoiler (I think he lowered it down so that only an extra 1" was on either side), but the surface area of the actual blade didn't hit the window anymore. The arm tension didn't push down in the right places.
  13. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I know this isn't physically possible on our cars, but some models of the Sienna have a really cool rear wiper that solves this problem by being hidden inside the rear spoiler at the TOP of the rear window. Just something neat.
    ztanos likes this.
