Question for potential prime buyer
Discussion in 'Prime Main Forum (2017-2022)' started by Carol DiPirro, Jun 26, 2017.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    The Prime's limit is 16A.
  2. JimE2017
    JimE2017 Junior Member
    29
    43
    Maynard, MA
    We traded a 2012 Plug in Prius Advanced two weeks ago for a 2017 Prius Prime Advanced, better acceleration and handling. Wife's drive to work is also 15 miles. At home we have a dedicated 20 amp, 120 Volt circuit for charging (Prius/Cord only uses 16 amps) first night charge took about 4.5 hours dealer did not charge car before delivery. Started the first drive to work with 24.3 in EV mode used about 10. plugged in at work 2.5 hours and drove home still had 15 miles left in the battery. Nightly charges are still going up this morning started with 34.2 . Been experimenting with EV and EV eco modes. Depending on your drive you should do fine. Her drive is back roads 35 to 40 mph and plugging in at home and at work she is using EV eco so as to use some gas, if not she would not use any gas which is not good for the car. This is her third Prius a 2nd gen 2004, a 2012 plugin and now the 2017 Prime, she also drove a Highlander Hybrid lots of practice with Hybrids.
  3. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    3.6 kW is the rate I'm able charge at, above the stated 3.3 maximum.
    HPrimeAdvanced likes this.
  4. Lee Jay
    5,850
    4,036
    3.6kW at 240V is 15A. I saw a maximum of 3.67kW on 240V, which is 15.3A.
    HPrimeAdvanced and john1701a like this.
  5. MNdriver
    MNdriver Senior Member
    549
    577
    I'll update y'all when I get the final decision. I did submit a proposal and had 2 electricians over to give me advice and an estimate. Fingers crossed.
  6. Carol DiPirro
    Carol DiPirro Junior Member
    25
    47
    New Hampshire
    Merrimack, NH
  7. Carol DiPirro
    25
    47
    New Hampshire
    Yes we have a lot of stranded costs........
  8. bwilson4web
    16,363
    It looks like ~$0.10/kWh which should make it economically viable.
    GOOD LUCK!
  9. Carol DiPirro
    25
    47
    New Hampshire
    Awesome, thanks, and then if I can hubby to put up solar........
  10. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    The L2 charger cost me net $100; Anaheim, California gives $1000 cash rebate if you install one!! TOTALLY worth it for me, since I need to charge multiple times most days to visit clients and/or run errands. Check your state and city for incentives!!
  11. Carol DiPirro
    25
    47
    New Hampshire
    New Hampshire needs to get with the clean energy incentives.. drive into VT and there are plugs in commuter lots!
  12. bisco
    52,383
    call the governors office! oh drat, you're back to republican.:p
    HPrimeAdvanced and Carol DiPirro like this.
  13. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I bought, but have yet to install a L2 charger. For me the reason to buy the charger is about having it outside all the time. Right now I run the supplied one on an extension cord and would rather not do that. Buying a L1 wall charger didn't make any sense since my eventual intention is to get a second EV so the L2 was the best option. That said, don't forget to look at total cost per kWh. In Mass right now it is about $0.20/kWh, This is after you account for all the delivery costs. I currently pay $0.083/kWh until I use up all that my solar panels will produce so it was a no brainer for me to move to a plugin vehicle. I am still riding on a $200 credit sitting in my electric bill so my hope is to break even at the end of the year.
    dalcon95, HPrimeAdvanced and bisco like this.
  14. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    I think you will need the severed foot of a furry animal for luck as well.
  15. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    That's bad luck!! For the furry three-footed animal!!
    Prius from Dad likes this.
  16. Carol DiPirro
    25
    47
    New Hampshire
    Thanks for all the help. I've got a Prius Prime today, notice new avatar. I'm sure I'll have more questions. I'm so excited, its charging now!
  17. bisco
    52,383
    congrats, all the best!(y)
  18. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    Nice avatar but you need to change the vehicle in your avatar. :)
  19. joachimz
    joachimz Senior Member
    451
    612
    17
    SoCal
    nice color :cool::cool:
  20. Carol DiPirro
    25
    47
    New Hampshire
    I did!
