5VDC power location
Discussion in 'Gen 4 Prius Main Forum' started by Stackmann, Jun 28, 2017.
  1. Stackmann
    Stackmann Junior Member
    We have a 2017 Prius 3. We have a dash camera located in the mirror. We could get power from the cigarette lighter, but then we would have a long cable hanging. We would like to get power from the overhead console. Any suggestions?
  2. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    You won't find any 5vdc in the console. Did you mean 12vdc?
  3. Stackmann
    No, I was hoping for 5VDC, but 12 VDC will do as I can use a step down transformer.
  4. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    If you do that, you need to use a transformer/power supply that came WITH the camera.....or is made for that use.
    And ......simple transformers do NOT work with DC power.
    Was that a typo when you said the camera is IN the mirror ?
    Did it come with the car.....or the mirror ??
  5. Stackmann
    Camera is from China.
  6. drysider
    823
    336
    Liberty Lake WA
    A 12vdc to 5vdc solid state converter is cheap and easy to find on eBay. I do not know about the availability of 12v in the overhead. Since the garage door opener is up there, I would guess that 12v is also.
    kithmo likes this.
  7. Stackmann
    Agreed, since there are dome lights as well.
    kithmo likes this.
  8. Sam Spade
    2,036
    1,024
    2017 Prius c
    And that answered exactly NONE of the questions I asked.
  9. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    From the dome light.
  10. Stackmann
    To Sam Spade: Sorry for not replying to all your message. I have a step down transformer ordered. I will tap into a 12VDC source in the dome light area and plug in the transformer. From there I will power the mirror mounted camera. The dash cam will store video on a 200 + GB card.
    The car did not come with a dash cam, I got it in China.
    Please consider my question answered and many thanks
  11. Sam Spade
    2,036
    1,024
    2017 Prius c
    Great. Looks like you have a good plan.
    BUT......referring to the part you ordered as a "step down transformer" is wrong and confusing.
    If it really IS just a transformer, it will NOT work for what you need.
    Using the right terms to describe things is important.
    If you want wine, you don't order grape juice.
    Most likely it is a mobile 5 V power supply, which is somewhat more than a simple transformer.
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  13. Sam Spade
    2,036
    1,024
    2017 Prius c
    Isn't USB 4.5 volts ?
    And USB might not supply enough current for the camera either.
    But it might be worth a shot; probably wouldn't hurt.
  14. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    3 amp is more then you'll need
  15. Sam Spade
    2,036
    1,024
    2017 Prius c
    And you KNOW that exactly HOW ??
    I stand corrected on the USB voltage.
  16. cnc97
    cnc97 Senior Member
    1,422
    1,536
    Evansville, IN
    My dash cam says it requires 5V 800 mA. So this converter could power it 2 1/2 times.
