Low mpg, time for a new battery?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jose725, Jun 29, 2017.
  1. Jose725
    Jose725 New Member
    My prius is a 2013 witg 85k miles. I think the hybrid battery is going out due to the heat.
  2. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    doubt it,just heavy foot
  3. bisco
    51,851
    welcome!
    maybe the tires, 12v, rubbing brakes, stuck emergency brake, clogged air filter, low oil and etc.
    but you can test the hybrid battery with tech stream.
  4. Jose725
    Jose725 New Member
    Went from steady 52 mpg to 36-42. That is a big drop
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,148
    Tampa, FL
    Big change in air conditioner use? It takes quite a toll when it gets over 90 degrees or so, especially if you have to park in the sun. It's not impossible, but it seems unlikely that a 2013 would need a new battery this soon.
  6. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    Do you have window tinting? I'd invest in a solar reflector for your dash.
  7. Jose725
    Jose725 New Member
    Yes sir I live in SE TX so it is 100 on a regular basis.
  8. Jose725
    Jose725 New Member
    Air filter was indeed changed today. Tires are almost ready to be changed and it is 100 here and I run ac often
  9. bisco
    51,851
    make sure you get a good set of low rolling resistance tyres.
  10. Jose725
    Jose725 New Member
    What do you recommend?
  11. bisco
    51,851
    i love the michelin energy saver a/s, but they are expensive, and may not fit gen 2. ecopia's are good i think. there are lots of tyre threads here with good advise.
  12. Jose725
    Jose725 New Member
    I noticed I went from 32 mpg in the 100 degree weather to 44 mpg as it cooled down
    jerrymildred likes this.
  13. Jose725
    Jose725 New Member
    Hear anything about Kuhmo tires on a prius? Good reviews?
  14. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    The heat will take a toll.......and make the HV battery a bit less efficient.....but likely won't do any permanent damage.
    You should still be under hybrid warranty so wait until the weather cools off a bit.
    Or take it in if it is due for other service.
  15. bisco
    51,851
    i've heard of kumho's but don't know anything about them. check tyre rack for reviews. i do like the 68 cent off special!:p
  16. Jose725
    Jose725 New Member
    I went ahead and got hankooks that were recommended to me at the tire shop. Saved about 100 bucks by buying them online and knowing someone who will install for free.
  17. bisco
    51,851
    great! i hope they are LRR.
  18. Jose725
    Jose725 New Member
    I believe they are. What if they are not?
  19. bisco
    51,851
    your mpg's will go down some more, depending on what you are replacing.
