Featured EVs have fewer repairs?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by Moving Right Along, Jun 22, 2017.
  1. EVs will have more problems
    1 vote(s)
    4.5%
  2. EVs will have the same number of problems
    3 vote(s)
    13.6%
  3. EVs will have less problems
    18 vote(s)
    81.8%
  1. Trollbait
    12,662
    Oil changes add up, and 100k miles will include a fluid change for the transmission in most cases. There is also spark plugs, and maybe a timing belt during that period of time. Then most gassers don't have regen braking. So at least on set of rotors and shoes all around.
    Coolant is the only fluid in a BEV; it can go five years or 150k miles in a GM. We know a Prius can go over 100k miles on the original brakes, and BEVs do more regen braking.
    They seem to have missed tires though.
  2. hill
    8,909
    .... plus fuel filters, PCV, smog checks come to mind.
  3. El Dobro
    El Dobro A Member
    7,088
    3,270
    Cat Converter, muffler, etc..
  4. bisco
    52,335
    you guys are thinking of the old days. our old camay's (i know, toyota again) required very little service up to the mid 100k's.
  5. hill
    8,909
    even modernly - fuel injectors will need cleaning - gas or diesel
  6. bisco
    52,335
    but at what mileage, and does gas brand matter?
  7. Trollbait
    12,662
    Those aren't regular wear items on current cars.
    I know the 2005 V6 Camry required a timing belt at 90k miles. Replacing those start at $100 if you are lucky. The longest interval for spark plugs these days is 100k miles.
    The $2000 figure may sound high but it is something spread out over 7 to 10 years.
  8. 3PriusMike
    3,101
    2,419
    Silicon Valley
    My Leaf just crossed two years since I got it. I brought it in for "service" a year ago and they rotated the tires and said I should bring it in more often. OK, so after 6 more months I brought it in and got a minor recall service done. Again, they asked me to bring it in more often -- it's free. I just think they want more practice rotating tires and keeping the car washer full. I got 3 years free maintenance...but the car washer was broken last time in.
    When it gets dirty again I'll bring it back in again after I make sure the car wash is working.
    (PIP is now 5 years old and no maintenance except oil changes. Free oil changes have run out. So the Leaf wins so far)
    Mike
    markabele and austingreen like this.
  9. Former Member 68813
    3,524
    983
    US
    this is a complete BS. Last time I checked, even EV need new tires. The $0 figure is a lie. Also, I didn't spend $0.02/mile in my Prius. More like $0.005 (including tires).
  10. 3PriusMike
    3,101
    2,419
    Silicon Valley
    It just means they haven't needed to buy new tires yet, I would think.
    My PIP is 5 years old and I haven't yet needed to get new tires.
    Mike
  11. Former Member 68813
    3,524
    983
    US
    well yes, but using this as evidence that EV cars have zero maintenance cost is a bit dishonest, isn't it?
  12. bwilson4web
    16,348
    Happily the Department of Energy conducts well documented fleet studies and shares the data including the number of service miles as well as the carefully collected maintenance costs.
  13. hill
    8,909
    this was proven to be true years ago. Remember how expensive 'new' Prius traction packs were originally? Now days, there are some pretty decent rebuild shops around - that can get you out the door with a rebuilt traction pack (& warranty) for ~$1,500. & - remember how much per kWh the original volt pack was estimated to cost? Yet Gen II's (iirc) are under $175/kWh new.
    #53 hill, Jul 1, 2017
    pilotgrrl and Trollbait like this.
  14. Trollbait
    12,662
    I don't think the Volt battery is that cheap. GM got a deal on the Bolt pack, but that was part of a package deal in which they buy all the drive train components from LG Chem.
    The kWh cost for Li-ion cells are likely under the value of the federal tax credit at this point though.
  15. hill
    8,909
    oops - yea my bad.
  16. Trollbait
    12,662
    Li-ion costs have made remarkable progress in cost reduction since the introduction of the Leaf and Volt.
    Toyota does have some valid reasons for sticking with NiMH in some cases, but it feels like stubbornness mostly.
  17. bwilson4web
    16,348
    Left over inventory of replacement traction battery packs?
  18. hill
    8,909
    Ha - that is kind of funny. But you have to admit, with the substantial amount of 1st-generation RAV 4 EV's still running around the landscape, some w/ over 100k & 150k miles, there is at least a little bit of validity to nickel metal hydride. And with our improved knowledge of thermal management & proper use of high & low (dis)charge limits, who knows ......
    of course - they DO keep saying that the Sudbury nickel mine is a pretty toxic place
  19. bisco
    52,335
    did this thread get scrubbed?:rolleyes:
  20. hill
    8,909
    Intermission - comedy show
