maintaining 12v Batt while using Techstream
Discussion in 'Gen 2 Prius Technical Discussion' started by RC-Pilot232, Jul 9, 2017.
  1. RC-Pilot232
    RC-Pilot232 Junior Member
    Maryland
    What is the the minimum voltage I need to maintain the 12v battery with the car, on in not-ready mode.
    So the HV Battery doesn't get depleted charging the 12v. While I learn Techstream? I have a server PSU that I have modded to output 13 volts 65 amps [for RC chargers]. I can change a resistor to get that up to 13.5v, amperage will drop, but shouldn't be an issue using it this way. Is 13.5 volts enough? And all lights & climate
    controls off.
    Thanks,
    Ned
  2. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    You need to output 13.6 V @ 2.5 - 4 A to effectively create a trickle charger.
    4 A is the maximum recommended current for the 12 V OEM AGM battery.
    #2 dolj, Jul 9, 2017
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Just buy a battery charger there not expensive and it's a good idea to maintain the 12 volt battery. I put mine on my 12 volt battery at least once a month to check its health.
  4. Fred_H
    Fred_H Misoversimplifier
    553
    476
    28
    Germany
    Maintaining at least 12.8 Volts will prevent the battery from discharging. That is not high enough to do any significant charging, but high enough to maintain the existing state of charge.
    #4 Fred_H, Jul 10, 2017
    KokomoKid and edthefox5 like this.
  5. Mendel Leisk
    38,723
    ^ This. Any half decent smart charger can be left on indefinitely. It'll run through a charging session, then revert to giving just slight, periodic charging, if and when needed.
    Raytheeagle likes this.
  6. RC-Pilot232
    Maryland
    Thanks everyone, but no one answered my original question.
    Ned
  7. bisco
    49,482
    12.8v per fred h in post #4?
    KokomoKid and Fred_H like this.
  8. edthefox5
    10,096
    4,806
    Clearwater, Florida
    How come you can mod power supplies but you don't know what voltage it takes to charge a 12 volt battery?
    That's a 5 second google if you really don't know.
    It takes 13.8 volts. Either at trickle 2 amp or fast charge 4 amp.
  9. RC-Pilot232
    Maryland
    Per the original post, I am not trying to charge the battery. I want to maintain it. While the
    car is ON in NOT READY MODE, and I am messing around with Techstream, for a few hours. Which will deplete the HV battery. Which I do not want depleted. And I have found my answer elsewhere, 13.8 volts.
    Thank You,
    Ned
    edthefox5 likes this.
  10. Mendel Leisk
    38,723
    What I don't get: a smart charger will do the job, and is good to have around, but that's not good enough? (n)
  11. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    Ned,
    It's known that the 2nd gen Prius in IG-ON (foot off brake, power button twice) mode will draw about ~200-250W to drive all of the car's ECU's (with all accessories off - obviously if you have headlights or other things on this goes up). I'm not sure what is in ACC-ON mode (foot off brake, power button once), but it should be the same or lower. So to stay in ACC-ON mode continuously, you'd need minimum 20A; I'd go for at least 25 or 30A to be safe. Anything from 12.8 to 13.8V should work great. Your 13V, 65A power supply is ideal really.
    Fred_H likes this.
  12. RC-Pilot232
    Maryland
    Thanks Kevin, I will try at 13v & see if the HV batt gets drained.
    Next time I get some time off work that is.
    Ned
  13. ChapmanF
    15,609
    That's because you asked a trick question, and nobody noticed. ;)
    Nothing will happen to the HV battery, which is fully isolated in not-ready mode, and isn't charging anything.
    You already got answers about the minimum output needed to prevent the 12 volt battery depleting (i.e. anything higher than its own open-circuit voltage) and that's all there is to worry about.
    -Chap
    Fred_H and valde3 like this.
  14. edthefox5
    10,096
    4,806
    Clearwater, Florida
    Oh yeah 65 amps is very ideal.
  15. edthefox5
    10,096
    4,806
    Clearwater, Florida
    You really don't understand anything about a 12 volt battery. Your only maintaining if it's at it's full 13.8 volts...fully charged. That's maintenance mode. Any other state below that voltage and it's charging.....it's drawing current.
  16. ChapmanF
    15,609
    I wonder how long additional posts will keep piling up without noticing the question was about the HV battery.
    dolj likes this.
  17. Fred_H
    553
    476
    28
    Germany
    Paraphrased:
    What is the the minimum voltage I need to prevent the 12v battery from being discharged, while the car is in ACC mode? (not in ready mode)
    again: 12.8 Volts
    https://priuschat.com/attachments/battery-soc-chart-jpg.59644/
    Spartacus and bisco like this.
  18. dolj
    dolj Senior Member
    7,652
    3,865
    If you read the question properly:
    The answer is the HV battery does not get depleted charging the 12 V battery when it is in ACC or IG-ON mode. So any trickle charger at 13.6 V @ 2 A will do the job as current drain in either of those modes will be minimal while playing with Techstream.
  19. bisco
    49,482
    was this one of those 'when did you stop beating your wife?' questions?(n)
  20. Kevin_Denver
    581
    422
    Denver, CO
    Well at least it wasn't another: "Go get your codes read" repeated x100 threads.:eek:
