Can you hear fliud flowing?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by peterooi, Jun 22, 2006.
  1. peterooi
    peterooi New Member
    Can you hear fliud flowing when the gas engine kicks in? I have had this happen after the car has been idle awhile. It sounds like a faucet flowing softly and continues for a couple of minutes and goes away... as if it equalizes in pressure or something.
    I have only had the vehicle for 3K miles and it has been in the shop to have the Coolant Valve (error code P1121) replaced. Although I cannot be sure I think the sound has been there since this Valve has been replaced. Then again the valve had issues at 150 miles and was replaced at 800 miles. Not sure if there is any connection.
    I have read other vehicles having the drain holes underneath the windshield wiper assembly being clogged might be a cause but this is not the case in my vehicle because it only appears when the engine kicks on and i checked the drain holes are clog free.
    Does anyone have any ideas?
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    The prius drain holes, regardless, evidently *do* have a propensity
    to clog up. I posted about this last week.
    As to coolant flowing ... too much air in the system could cause
    that; I'm pretty sure I heard bubbling in my old Subaru. Didn't
    worry about it too much since it was clear that fluid *was* flowing
    and carrying heat anyways..
    _H*
  3. peterooi
    peterooi New Member
    Hobbit.... I am assuming you do not hear it in your Prius?
  4. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    Are you sure you are not hearing the "buzzing" sound that happens when braking? It could sound something like you describe, but does not last for minutes, just seconds
  5. peterooi
    peterooi New Member
    <div class='quotetop'>QUOTE(mssmith95 @ Jun 23 2006, 01:38 AM) [snapback]275692[/snapback]</div>
    I'm positive. This is happening when I accelerate and the engine kicks in. Dealer told me to bring it in at my 5K oil change.... they didn't think it was a big deal. In fact they thought it was normal. Since I have not had a chance to compare this with any other vehicle its hard to know what is normal.
  6. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(MoreMiles @ Jun 23 2006, 02:47 PM) [snapback]276006[/snapback]</div>
    No, I even double checked today...no sounds like that ever.
  7. galaxee
    galaxee mostly benevolent
    9,810
    470
    MD
    is this the same sound you hear when the car shuts off and the coolant is being pumped into the canister? it may sound a little different from the inside of the car. otherwise, hmmm.
  8. peterooi
    peterooi New Member
    <div class='quotetop'>QUOTE(galaxee @ Jun 24 2006, 10:29 AM) [snapback]276310[/snapback]</div>
    Not really. It just sounds like fluid flowing for a couple of minutes and then it stops... as if it has pressureized or something.
    What is really weird is that the sound just stop in the last few days. One major difference and may be unrelated is that the temperature outside is much warmer now.
