Winter Driving
Discussion in 'Prime Main Forum (2017-2022)' started by jjameson, Jul 7, 2017.
  1. jjameson
    jjameson New Member
    Deerfield, IL
    Hello, I am new to this forum. And, actually, I do not own a Prius Prime... yet. But I am planning to buy one in the next 6 months. Because I live in Illinois, I must order one (no Primes at the dealers near me). And, therefore, I cannot test drive one. So I am trying to gather as much information as possible. Here's my question: does anyone have any real winter driving experience with the Prius Prime? Driving performance? Battery/MPG performance? Etc. Thank you.
    HPrimeAdvanced likes this.
  2. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    here's what I experienced last winter......
    ICE comes on anyway | PriusChat
  3. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    5 years of Minnesota driving with the gen-1 plug-in Prius. No trouble whatsoever, great efficiency, but EV was cold without electric heat.
    This year with my Prime was brief, the end of Winter. The heat-pump was nice. I look forward to the climate-prep. For most defrost, no engine necessary. Just the window-blow setting works fine.
    The curved back window funneled light snow nicely. Not sure what heavy snow will be like.
  4. Ryan c
    Ryan c Junior Member
    39
    Denver, co
    One thing to consider is buying from the northeast instead of ordering. Currently Maine and Massachusetts are discounting Primes (premium and advanced) by 5k. I live in Colorado and instead of paying msrp, bought one from Maine (Berlin City Toyota in Portland) a few weeks ago.
    FuelMiser, Ookies, bodgm and 2 others like this.
  5. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    Did OK driving on ice with Michelin Xi3 snow tires. Low clearance--won't go though deep snow.
    priuscatprimeguy likes this.
  6. jjameson
    jjameson New Member
    Deerfield, IL
    Any more specifics on battery/MPG performance? I currently own a 2007 Camry Hybrid in the Chicago area. I've experienced the following for 10 years now: Warm-weather performance is in the 36-38 MPG range. Cold-weather performance is in the 31-33 MPG range. Can I expect the same difference with a Prius Prime?
  7. MNdriver
    MNdriver Senior Member
    549
    577
    I'm curious too. I got my Prime in May so did not have cold weather experience. With the 2009 Prius I sold I got 46 mpg in summer and high 30s in our Minnesota winters.
  8. Prius from Dad
    Prius from Dad Senior Member
    724
    1,116
    Toms River, NJ USA
    I bought mine January 31. During Feb and March, when the temps were in the 20's and 30's, I was getting between 22 and 28 EV miles per charge. I will look up my mpgs when I get home tonight and post back here.
  9. MNdriver
    549
    577
    I grew up in South Jersey. I know South Jersey. South Jersey was a friend of mine. South Jersey is not winter.
  10. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Hey JJ, we should get together at some point. I live and work relatively near you.
    I seriously considered that. I even have a support system in place with friends/coworkers in multiple states who could pick me up at the airport and give me a place to sleep. But it was the uncertainty of showing up at an unknown dealership with no fall-back that scared me. I've never had anyone brazenly pull a bait-n-switch but I don't want to be several states away with no way home when it happens. In the end, I went to Smart Toyota in Madison, WI because I know their head hybrid guy.
  11. huskers
    huskers Senior Member
    2,544
    2,487
    Nebraska
    107 degrees heat index here today and you folks are using the "W" word. Just not right.
  12. priuscatprimeguy
    2,730
    2,640
    "W"att?:confused:
  13. Mendel Leisk
    41,315
    Not specific to the Prime, or Prius for that matter, but if you're intending to get snow tires on separate rims, read up on the Tire Pressure Monitor System.
    My suggest, if it's possible in your area, for simplicity, just waive TPMS sensors on the snows, which means you live with a little warning light during those months.
    If you do get TPMS sensors, expect and upfront additional cost $30~50 per wheel, and likely an initialization charge from the dealership of maybe $50~100 to get them identified by the car's sensors.
    This last charge will continue, twice yearly, with each wheel swap. Unless you bone up on TPMS tech and invest in the hardware needed to DIY the initializing procedure.
    There's a Corolla steel rim that's compatible, and simple lug nuts. Or aftermarket rims, or rolls royce it: get Toyota rims.
  14. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Bridgestone Blizzaks on 15" steelies for the winter (sans TPMS, so ignore the NagLight :eek:) (42F/40R), and Antares Ingens A1s (46F/44R) on 16" OEM alloy rims for the summer (with TPMS, and the State Inspection is at the end of June, so all is well as far as being legal for inspection etc. etc. ;))
  15. Mendel Leisk
    41,315
    Oh yeah: some US states require tpms light out, and some don't care?
    And federally: tire shops are not allowed to do installs on tpms car without sensors? But there may be loopholes, and/or lax compliance?
    It's a can of worms, for sure.
  16. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    jjameson | PriusChat & MNdriver | PriusChat MNdriver that's cool. I know we don't have serious winters like you do, even like we used to when I was a kid. But this is all I can go by with what you are asking. So take it for what it's worth. Her are some charts showing my EV miles using temperatures and my daily mpg's by date. Hope this helps a little. :)
  17. TonyPSchaefer
    14,816
    2,500
    66
    Good point. When I get home this evening, I'll try to remember to share my charts since almost all of my driving was done in JJ's neck of the woods.
    Prius from Dad likes this.
  18. NJ-PrimeAdvanced
    204
    134
    New York/New Jersey
    What app do you use to create such cool charts and with temperature and everything? this is not fuelly is it?
  19. Prius from Dad
    724
    1,116
    Toms River, NJ USA
    It's not an app, it's MS EXCEL. I put my trip notes in a spreadsheet. These charts are only from my 72 mile round trip commute. I use fuelly for my total mpg's per tank and also EXCEL. I only have 6 month's of data for my tank mpg's so it wouldn't make much of a chart. When I get a full year of data, I will do one for monthly.
  20. TonyPSchaefer
    14,816
    2,500
    66
    Here is a Regression Chart I created with Minitab after about three years of driving. Of course, you have to keep in mind that this is a 2004 Prius. I don't have any experience with a Prime in the Winter yet. But to answer your question, yes, we all see diminished mileage in the Winter.
