Battery over heating
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SnT08Prius, Jul 14, 2017.
  1. SnT08Prius
    SnT08Prius Active Member
    158
    187
    Bozeman, Montana
    So the 2008 Prius with 209,000 mile spat the dummy yesterday and had to be towed home. Had red triangle and service car light on. Little power and the HV battery fan flat out.
    Disconnected the battery and that cleared the warnings, but the car started to surge when lifting off to coast at 30+ MPH. Drove for about 5 miles and symptoms returned. Reset the battery again and made it home.
    Took the HV fan out and it was dirty. Just maybe that was it. The car drove ok for 15 miles after that so parked for the night.
    Next day the car did about 100 miles and the battery too hot again. Stripped everything back so I could see teh fan working and it was.
    So I have pulled the battery out and shall have a look over it tonight and see if there is any bad cells or corrosion on the copper tags.
    The surging was not there last week and we have done 18,000 miles this past 6 months, so I am hopeful the battery has an issue I can fix.
  2. SnT08Prius
    158
    187
    Bozeman, Montana
    The car was working fine the other day in 122f heat....
  3. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Clean the traction battery fan there dirt in the blades or the intake vent clogged Passenger side behind the back-seat
  4. SnT08Prius
    158
    187
    Bozeman, Montana
    Thanks Jmack111, I did that last night and the car did work better for a while - but soon began to play up today.
    I scanned for codes but there were none set. Yet!
  5. fotomoto
    fotomoto Senior Member
    5,639
    3,814
    So. Texas
    I'll assume you're in AZ, NV, or the southwestern CA area but anyways, heat kills HV batteries. The car threw diagnostic codes, get them read with a reader that can see ALL codes including Toyota's hybrid specific ones. Generic readers can't.
    SnT08Prius likes this.
  6. SnT08Prius
    158
    187
    Bozeman, Montana
    Yes in AZ! The car is in bits now. Will check the battery cells tonight and see what they are reading. I have access to some second hand units if needed.
  7. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Was fan dirty? May have dirt around the battery blocking air flow too
    Heat will kill a weak cell too my 50% and return with normal temps
    The battery level drop or go up after sitting over night. May point to a weak cell
  8. SnT08Prius
    158
    187
    Bozeman, Montana
    I have the battery out - but not at a work bench yet - waiting for the trolley to come home. The fan was dirty for sure.
    I suspect there my be fluff n stuff within the battery case blocking air flow.
    Over the past month I have noticed the bars going up n down a little quicker and it struggled through the mountain climbs we did 2 weekends in a row. So maybe a few cells have dropped performance and now just a little too much for it.
    I hope tonight I can find something to point to this failure. Else put it back together and head off to Toyota for a scan readout.
    hotelprisoner likes this.
  9. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    How is the HP? When you Engine on? And is there Drag gliding
  10. SnT08Prius
    158
    187
    Bozeman, Montana
    The power is there once the 12v battery has been unplugged for a bit. Charging seems ok when braking up to the lights, but the car surges now when coasting along at 30+ mph - so I just did the on off the gas to avoid that issue.
    Spoke to a bloke that rebuilds batteries and he offered the following: Clean fan (as you suggested) and then clean contacts on the battery, test all cells for volts. Get back to him after that.
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
  13. SnT08Prius
    158
    187
    Bozeman, Montana
    So the"VVT" thingo is the surge issue? plus a poor performing battery :) I think I remember looking into that 10,000 miles ago. It was a valve or something and it had been replaced not so long ago. But the throttle body may need a good clean. So sort the battery first and then look under the hood! :)
  14. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Not so much battery. But am Green more. So yes and no.
    Your battery problem bigger
  15. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    It cam timing. Sensor and runs off oil pressure and the filter get clogged. I glide x2 as far now
    Easy fix. I move spark plug 1 coil to spark plug coil 3 too 1 works harder I just replace them after that test
    I have 3 prius. boosted from 30mpg to close to 50mpg (freeway) all of them
  16. SnT08Prius
    158
    187
    Bozeman, Montana
    Hmmm - will have a look for sure at this. Our Prius does about 1,000 miles per week now and could do with a MPG boost :) Cheers
  17. SnT08Prius
    158
    187
    Bozeman, Montana
    Checked all the cells and they came up 7.8 for all 28.
    So put the car back together in the morning and off to see if we can get any codes out of it.
  18. SnT08Prius
    158
    187
    Bozeman, Montana
    Battery back in and 100 mile road test in 111F heat and not once did the battery play up. The car still surges at around 30mph coasting so will look under the bonnet tomorrow when the engine is cool enough to work on. The throttle body spring seemed free enough.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Car not in garage your letting the interior get extremely hot no windshield shade and cooking the battery.
    Extend the cloth package rack to cover the battery area in the back crack the windows
    And get a good high heat rejection tint. Don't cheap out. You may have a tint but it's crappy and no modern heat rejection. Get at least 85% rejection. Never been hotter.
    Your British living in AZ. What does "spat the dummy" mean?
  20. SnT08Prius
    158
    187
    Bozeman, Montana
    The car is on the road and has good tint as such - but is 5 years on the car now, so maybe a time to upgrade. I'm an Aussie living in AZ LOL and spat the dummy is a saying from where I come from that indicates the car is not behaving well :) - ie kids spits the dummy out when unhappy.
    #20 SnT08Prius, Jul 16, 2017
