Inverter Coolant Oily
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by CapTech, Jul 15, 2017.
  1. CapTech
    CapTech Junior Member
    laurel, Maryland
    Good evening!
    I was just looking at all my fluids and checking things out since I reached 120K a couple months ago in my 2010 Prius II. One thing that concerned me was there was an oily-ish skim on the top of the inverter coolant. The color looked fine, there was no debris, and the level was fine. There was some dried up white stuff on the inside of the cap though. Does anyone know what the oily-ish skim or dried up white stuff could be from? And do I need to replace the coolant, or inspect anything else as a precaution cause of the oily film?
    Thanks, and I'll try to post pictures tomorrow when its light out!
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,693
    1,737
    Bay Area
    Posting a picture would be good. not sure what the oil film looks like. The dried up white stuff could be old coolant that dried up from sitting in one place for too long and it drys up from the engine heat. I mean these are my guesses, won't know for sure until we see it and figure what's the issue.
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    just replace it
  4. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    I can't think of a way oil from the engine could get into the inverter coolant circuit. It could be a tiny bit from assembly lube used when the car was made. A small amount (a skim or sheen on top) won't harm anything. Replace the fluid when called for by Toyota (they have extended the interval, doubling it now from what it was).
  5. Mendel Leisk
    41,333
    Yeah but transaxle fluid?
  6. David Beale
    5,963
    1,988
    Edmonton Alberta
    No, not even transaxle fluid. The inverter is separate from all mechanical parts, only joined by wires.
  7. Mendel Leisk
    41,333
    The inverter coolant drain bolt is on the underside of the transaxle though, maybe coolant channel run through the transaxle as well? (n)
    With thanks to @NutzAboutBolts :
    And from the Repair Manual:
    Raytheeagle and NutzAboutBolts like this.
  8. NutzAboutBolts
    1,693
    1,737
    Bay Area
    we won't know until we see the pictures :(
  9. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    According to what I've read, the inverter coolant does take a trip through the MG's, cooling the stator windings. Don't know about the oily. Could have been from assembly, if the SLLC is original. Or maybe somewhere down there the SLLC is encountering ATF-WS.
  10. David Beale
    5,963
    1,988
    Edmonton Alberta
    Well, wherever it runs, I wouldn't worry about it unless it turns "milky". A tiny bit of oil (film on top) won't harm anything.
  11. Mendel Leisk
    41,333
    Yeah that could well be some assembly grease, as you said.
  12. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    Unless the OP is the only one to have ever touched the engine bay since new, someone over the past 7 years could have begun to mistakenly add another fluid (brake or oil) to the inverter coolant tank and stopped after putting a few CC's in when the mistake was realized. o_O It's a possibility.
  13. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    Looking at the drain photo. The fluid got all over the bottom of the transaxle case. Any oil on the bottom of the case may have been washed of by the draining fluid, and this could make the small oily sheen at the top of the drained fluid.
    Photo from @NutzAboutBolts :
  14. Mendel Leisk
    41,333
    Maybe the drain pan was also used for oil changes, some residue?
    Raytheeagle and Rebound like this.
  15. fotomoto
    5,632
    3,810
    So. Texas
    Or the same funnel used for oil changes was used without cleaning to change out or top off the coolant tank.
    Raytheeagle, Rebound and Mendel Leisk like this.
  16. Mendel Leisk
    41,333
    Yeah even if oily plastic is wiped with a clean cloth it'll retain a bit of oil. I try to segregate funnels: one for coolant or washer fluid, one for engine oils, a long tapered one for Honda auto transmission, a special one with hose for Prius transaxle, another similar one for Honda rear differential. I've got a funnel corral lol.
    RMB and Raytheeagle like this.
  17. Rebound
    3,996
    2,644
    Portland, OR
    I have a funnel.
  18. Mendel Leisk
    41,333
    The medium sized white one, middle-back, is for adding motor oil. Biggie, at left-end-back is the drain oil catch funnel. White one directly in front of it is for coolant and washer fluid. Tiny one front-left with long hose extension is for Honda rear differential. Black one front center has a 3' hose extension (obscured), for Prius transaxle. Kirkland mayo jar (hole in lid) with syringe, tube and adapter is for brake fluid change. And indispensable graduate. There are more funnels/tubes, just haven't needed them yet, lol.
    RMB, mjoo, Raytheeagle and 1 other person like this.
  19. AzWxGuy
    AzWxGuy Weather Guy
    1,051
    536
    Tucson, AZ
    2021 Prius
    Where is the OP? Scared away with all our speculating?
    Raytheeagle likes this.
  20. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    He might not return given how many funnels @Mendel Leisk has.
    I have 2 funnels: one with a large opening and one with a small opening;).
    Contamination at minute levels should not pose any long term damage to the systems.
    But creates great conversation (y).
    RMB and Mendel Leisk like this.
