ATF fluid changes ARE Required.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bill Norton, Dec 15, 2012.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Persistence pays off(y).
    MMtec likes this.
  2. Mendel Leisk
    41,950
    49.20 euros currently equals 72.17 canadian dollars, works out to $14.43 (can) per liter, $11~12 US. Getting better anyway. (y)
    MMtec likes this.
  3. Tideland Prius
    16,623
    Why do you think the tech companies are going for car sharing? In the users' minds "not my car, don't have to deal with it. Just drive and leave it at the destination".
    That does leave a different set of problems but I won't get into that.
  4. MMtec
    MMtec Junior Member
    48
    Portugal
    Finally I change them!!!! It looks black ⚫️⚫️⚫️
    When I picked up the Atf att the dealer, he says:
    (He)Why you change this oil???
    (Me) Because it's needed.
    (He) you have a leak, level low, or a problem with gearbox?
    (Me) No, I have no problems... Just preventive maintenance!!!
    (He) But isn't needed. We don't change this here. We normally don't have this oil in stock. It's Lifetime fluid!!!!
    (Me) Don't exist lifetime oils.... and I want my car running more than a life.
    Finally, he agree with me!
    Later I put pics.
  5. Mendel Leisk
    41,950
    Dealerships vary a lot in attitude; ours always has Toyota ATF WS in stock, and the fill/drain bolt washer, no hassles.
    MMtec likes this.
  6. Fred_H
    Fred_H Misoversimplifier
    560
    485
    28
    Germany
    But lifetime oils do exist. In fact they have been around since WWII, when they were used quite successfully in kamikaze airplanes.
  7. MMtec
    MMtec Junior Member
    48
    Portugal
  8. MMtec
    MMtec Junior Member
    48
    Portugal
  9. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    A Few Takeaways from This Thread and personal experience that I found useful to improve the maintenance procedure:
    • Take the entire engine bottom cover off for a cleaner job.
    • Get some new clips because they tend to break eventually.
    • Clips accumulate grit that locks the mechanism, so it's worth washing them after removal for easier reinstalling.
    • The aluminum washer for the fill/drain plug is actually called a gasket by Toyota (LOL). The part number is 90430-18008 (Transmission Drain-fill plug gasket). If you prefer to use new ones rather than reusing them, this is the one to look for.
    I bought my 2013 Auris Touring Sports (very similar to a Gen 3 Prius) back in late 2016 with 40k miles on the clock. Unfortunately, I learned too late about the necessity of transaxle fluid replacement—Toyota doesn’t include it as part of routine maintenance in their literature. I finally did the replacement in 2019 at 74k miles using a funnel with a clear tube attached.
    Back then, I wasn’t sure if the car was perfectly level, so I inspected it 9 months later at 81k miles and ended up adding around half a quart. I recall using 4 jack stands at the time.
    Now, at 106k miles, I’ve been busy with maintenance! Here's what I've done recently:
    • Oil change and replaced the oil filter.
    • Cleaned the HV battery fan (or "blower" as Toyota calls it ) and installed custom filtration using vacuum cleaner filter fabric—this Miele AirClean filter that I had lying around.
    • Completed my first engine coolant change. I know, I did it late (11.5 years), but better late than never, right?
    For the first time, I opted for third-party products instead of Toyota OEM parts because I can no longer justify their pricing. Here's a rundown:
    Engine Oil: I paid £25 (~$31) for Mannol oil, while Toyota quoted me £126 (~$156) for their AFE oil.
    Oil Filter: I’ve been using K&N oil filters that I bulk-purchased back in 2020 for $4.73 each.
    Cabin Filter: Active carbon cabin filter Blue Print ADT32522 cost me €6.94 (~$7.55), while Toyota sells theirs for a whopping £116.78 (~$145). I assume, the price hike is due to the piece of sponge they added to the side—madness!
    Coolant: I opted for LLC RED coolant at £32 (~$40) for 5 liters (makes 10 liters). Toyota sells PINK coolant at £54 (~$67) per 5 liters—that's £108 (~$134) for 10 liters. Not to mention, I dislike the "girly" color of the SLLC.
    I’m sorry for the long post, but with this thread spanning 35 pages, I felt it was worth catching up!
    Getting Back to the Transaxle Fluid Topic:
    I have some questions and would love to hear your opinions:
    1. As I've only done 30k miles since the last replacement, but it's been 6 years, am I due for another change? I keep reading that 60k miles is suitable for a second change, but does time factor in the same way as with engine oil changes (whichever comes first)? I assume yes.
    2. Apart from Toyota ATF, what alternative fluid would you recommend?
    3. Can I even do this properly with only 2 jack stands and a 2-tonne floor jack?
    4. Lastly, what maintenance tasks would you suggest at 106k miles to keep everything running smoothly?
    Any advice is greatly appreciated. Cheers!
    #689 Fostel, Apr 4, 2025
  10. BiomedO1
    4,223
    2,204
    SacTown, Ca
    IMHO; the first ATF change is the most important; dumping out break-in and assembly contaminates. The transmission is mostly a sealed unit with a vent cap - very little wear components and no combustion blow-by to contaminate it.
    I'd stick to the Toyota ATF-WS or Aisin ATF, manufacturer of the transmission. Don't know how those multi-vehicle fluids will interact with the electronic components; may cause insulation break-down over long periods of time and heat cycles. The Toyota ATF-WS is a known variable.
    I have a slopping driveway and place the car on my oil changing ramps. Use the floor jack to raise the rear and level out the car.
    I may have missed it; have you flushed out your brake fluid system? Those drive-by-wire braking systems don't handle contaminates very well. Make sure it's an entire brake system flush, they're not just replacing the brake reservoir fluid.
    Hope this helps.....
    Fostel likes this.
  11. MAX2
    MAX2 Senior Member
    1,436
    488
    101
    Third planet from the Sun
    The fluid is poured in for long-term use and there is no point in saving.
    Pour in the original.
    Calculate how much the cost of one mile or a hundred miles will increase if you divide the cost of a canister with transmission fluid by 30-40 thousand miles.
    Compared to the cost of fuel, this is a pittance.
    Fostel likes this.
  12. Bill Norton
    Bill Norton Senior Member
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    The "original fluid" is just toyota's generic ATF that is used for their entire fleet.
    (although, I think I read that there is finally an improved ATF that is called out on some later model vehicles.)
    There are no 'electronic components' in the transaxle. There are two Motor/Generators and the bigazz wires that feed them. These are simple electrical components.
    I've been using high quality synthetic lubes for decades, for every application.
    Why not spend a few dollars more while doing this work?
    Or buy the generic house brand,, and,, that oughter be good enough.
    Fostel likes this.
  13. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    After reading through these fascinating threads, I've made up my mind—I'll be changing the transaxle fluid as soon as possible, and I've decided against using Toyota ATF fluid.
    Lexus Toyota "Lifetime ATF" - baloney
    WS transmission fluid is garbage. Get it out of your transmission now
    Verified alternatives to Toyota WS ATF - Automaitc Transmission Fluid
    What ATF/CVTF to use for Toyota?
    :D
  14. ASRDogman
    ASRDogman Senior Member
    7,844
    3,997
    Why would you want to use the stuff designed for the car?
    Throw any cheap fluid in it, it doesn't matter...fluid is fluid.
    Of course you won't find anything the cost more than pennies less.
  15. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    Thanks for your input, Dogman. I think there might have been some misinterpretation here. My decision to change the transaxle fluid isn’t about using 'cheap fluid' or disregarding what’s designed for the car. Quite the opposite—after reading through various datasheets and tests (including those shared in the last link), it’s clear there are fluids available that meet or exceed the specifications of Toyota WS, offering better thermal resistance and long-term performance.
    Even the manufacturer, Aisin, which builds many Toyota transmissions, produces its own ATF and recommends fluid replacement, contrary to Toyota’s 'lifetime' claims. My goal isn’t to cut corners but to find a higher-quality, compatible alternative at a reasonable price.
    I respect differing opinions, but dismissing researched facts and shared insights without reading them does no one any good. Let’s keep this discussion productive instead of jumping to conclusions.
  16. ASRDogman
    7,844
    3,997
    You gave no other information about checking other fluids.
    I never jump to conclusions. I base my conclusions of the information I'm given.
    If you want to waste your money on anything other then the correct item, it's yours to waste....
    So: ...but dismissing researched facts and shared insights without reading them does no one any good. Let’s keep this discussion productive instead of jumping to conclusions"
    "After reading through these fascinating threads, I've made up my mind—I'll be changing the transaxle fluid as soon as possible, and I've decided against using Toyota ATF fluid."
  17. Bill Norton
    2,219
    746
    MONW, Ks.
    2019 Prius
    L Eco
    You state this, and then you say you'll use the generic ATF that toyota sells for every dang vehicle in their fleet.
    It's not synthetic. It does not offer "better thermal resistance and long-term performance".
    Draining the crud out from the original fluid and replacing it with new fluid is the main thing. (y)Carry on !
    Me? I just always look for 'better than stock' when working on cars, and Mobil1 or Redline offers such fluids.
    You use synthetic motor oil, correct? Better than the cheap stuff, that still has the same spec number, right?
    I'm the OP that started this thread, some 13 years ago. I paid extra for the Oil Analysis pages displayed.
    The claim that WS protects the wires and insulation on the stators is just silly.
    Has there ever been a report of 'Insulation Breakdown' in a Prius transaxle?
    #697 Bill Norton, Apr 5, 2025
  18. ChapmanF
    18,590
    Yes—replacement of shorted and burned MG2 stators was kind of an industry for gen 1 (which used a pre-WS oil Toyota called T-IV).
  19. Mendel Leisk
    41,950
    But wait: Toyota ATF WS is not “synthetic”, so… :ROFLMAO:
  20. Fostel
    Fostel Member
    96
    30
    Kent
    Excel
    Thank you for the response and for quoting my post! I think there might be some confusion about my stance. I explicitly mentioned that I'm looking for alternatives to Toyota WS fluids—ones that offer better thermal resistance and long-term performance. I want to steer clear of overpaying for the generic fluid Toyota sells, and my goal is to find a superior product that works well for my vehicle.
    I appreciate the mention of Mobil1 and Redline—I'll definitely consider them as part of my research. As for the claim about WS protecting wires and insulation, I agree it's doubtful. It's reassuring to know that there haven’t been reports of insulation breakdown in Prius transaxles.
    Thanks again for engaging in the discussion, and I'd love to hear more insights from your 13 years of experience with this topic!
    Bill Norton likes this.
