Won't start - 2003
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Billsun3, Jul 4, 2006.
  1. Billsun3
    Billsun3 Junior Member
    2003 Prius
    I inadvertently left the key in the ignition in the on position (2003 Prius). When came back 2 hours later, dead, dead, dead.
    Waiting one hour - nothing. Waited two hours - nothing. No ligts, buzz-beep, radio - nada.....
    So will it recover or do I tow it to the dealer?
    Wondering...
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(BillSun @ Jul 3 2006, 09:13 PM) [snapback]280820[/snapback]</div>
    just boost the 12 volt battery but you'll probably need a new one as they never fully recover.
  3. ghostofjk
    ghostofjk New Member
    979
    No, that little 12V won't recover, but why don't you jump it instead of towing to the dealer? Or, if you have AAA, have them jump it. (Jumping contact point, as per OM, is under hood, on right side, under plastic box cover---be careful making sure you release ALL fasteners on sides---I broke mine by not releasing one, and that little plastic piece of nothing costs $87!)
  4. Sufferin' Prius Envy
    3,998
    I disagree with replacing the battery!
    I helped a neighbor jump a 2002 Prius suffering the same fate. Two years later, the 12 volt battery is doing fine.
    Any 12 volt lead-acid battery, especially if it is/was still in good condition, can still lead a useful life if it had been drained and not left discharged for long periods of time. The Prius batteries, both the traction battery and the 12 volt battery lead pretty pampered lives. The Prius 12 volt battery, unlike a regular car battery, is not called upon to provide massive amperage to crank start the ICE. To just summarily replace the 12 volt battery is wasteful thinking. I would give it a chance to prove it can still do its cushy job. :)
    Jumping a Prius is not the same as jumping an old technology car. Basically it just needs enough power to get the computers up and running, not massive amperage to simultaneously overcome a dead battery and crank over the car. Even a detached car battery or a deep discharge battery (marine/RV) carried to the Prius would be more that adequate to do the job.
    Remember: No using a Prius to jump start another car . . . unless maybe another Prius. We're snobs that way. :lol:
  5. haceaton
    haceaton New Member
    27
    I too disagree that the 12V battery should be replaced just because it was discharged once. My 2002 had it's battery discharged (by leaving the interiror lights on overnight) and I simply recharged the battery. It's been fine ever since, or about 2 years.
    If you don't have a charger, simply jump start the car, then leave it in a "ready" state (feel free to drive it or park it) for a couple of hours. Don't run too many accessories (lights, fan, radio) during that recharge time. Chances are the battery will be fine.
  6. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    No using a prius to *jump* another car, perhaps, but it's certainly
    valid to use a prius to *charge* another car for a little while until
    it can start itself. Which should be tried after you've unhooked,
    of course.
    _H*
  7. Billsun3
    2003 Prius
    <div class='quotetop'>QUOTE(hobbit @ Jul 4 2006, 08:02 AM) [snapback]281005[/snapback]</div>
    Thanks - will do
    Bill Sun
    <div class='quotetop'>QUOTE(BillSun @ Jul 3 2006, 08:13 PM) [snapback]280820[/snapback]</div>
    Thanks to all who gave advice.
