How to get behind front bumper to push out dent
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TryingToLearn, Aug 4, 2017.
  1. TryingToLearn
    TryingToLearn Junior Member
    santa monica, ca
    Hello, I have a dent on the right hand side of my 2010's front bumper.
    I've watched countless videos of people heating up their bumpers and then pushing the dent out from the inside. I can't for the life of me, however, find instructions on how to remove the black flaps under the car to get access into the bumper. Any tips would be very appreciated!
    Pics below of the area I'm talking about, plus the dent. I'm a broke student, so taking it to a repair shop for $400-$1000 repair isnt an option for me. :(
  2. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,692
    1,737
    Bay Area
    The bottom plastic piece is held on by a bunch of clips and screws. You can use a flat head screw driver to unclip the clips. If you watch my transmission fluid drain and refill on the Prius, I think we showed how to remove the bottom panel... or one of the video on there. Good luck!
  3. TryingToLearn
    santa monica, ca
    Thanks! I just looked it up, and the bottom panel is the panel on the belly of the prius right? I'm looking more whatever you call the panel directly behind the front bumper that surrounds the wheel well. I tried locating as many screws and pins as I could and taking them out, but still not able to remove the flaps to get behind the bumper.
  4. NutzAboutBolts
    1,692
    1,737
    Bay Area
    I think you'll have to pull the front bumper off of the car to get behind there, or you can try removing the wheel and the fender lining. The bumper is mounted on the bumper support.
  5. NavyLCDR
    NavyLCDR Active Member
    201
    125
    Lebanon, OR
    2024 Prius
    XLE AWD-e
    The piece you are showing in your photos is called the fender liner. There are a series of clips and screws starting all the way from in front of the front door behind the wheel/tire, and going all the way to the front bumper edge. Look up fender liner replacement.
    It might be easier to just remove the front bumper. I've replaced both fender liners and my 2011 and have also removed and replaced the front bumper. I think the bumper itself is the easier.
  6. Buderim
    Buderim Junior Member
    28
    Queensland Australia
    i-Tech
    heiwa and Raytheeagle like this.
