Rotten Food/Dirty Socks smell coming out of vent?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by TS1111, Aug 4, 2017.
  1. TS1111
    TS1111 New Member
    CALIFORNIA
    I have a brand new 2016 Prius that when the vent is on (actually it smells when it switches between A/C on and off), it gives this strong rotten food/dirty socks smell. I checked other threads in the forum, and opened the air filter and reached in to see if there was anything in the blower motor and both were new and clean. I smelled the vent too just to make sure there wasn't any rodent urine or anything like that and it smelled brand new.
    So I turned on the air while having the filter compartment open, and the smell was very noticeable when switching between A/C ON and OFF. So if it's not the filter and the blower motor, where else could this problem be? The smell can be very strong sometimes when the car has run on A/C for a while and if A/C all of a sudden was switched off, the car would stink like crazy. All your help is greatly appreciated!!!
    52,193
    sounds like you need a/c cleaning. you can show it to the dealer, try some lysol/baking soda, or auto parts shoppes will have deodorizers.
    RCO likes this.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Usually it is mold in the AC system.
    Since in 3 months the 2018's will be out, if your 2016 is really "brand new" it could actually have been rolled onto the lot 21 months or more ago. That's lots of time for growth.
    RCO, Prodigyplace and CoastRider like this.
  4. TS1111
    TS1111 New Member
    CALIFORNIA
    How to clean the mold out?
  5. TS1111
    TS1111 New Member
    CALIFORNIA
    Went to the dealership, they said they sprayed something in there, but it only worked for like a day, not even...
  6. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Is the drain hose working? - ie draining condensate under the car onto the ground.
    RCO and CoastRider like this.
  7. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    That's a good question, come to think of it, I've never seen any water spots under my car. And I run the AC every day.
    But thankfully, I've never had a rotten sock smell! :ROFLMAO: I wonder exactly "where" the dealer poured some stuff? How about pouring something in the vent that is outside the car, at the bottom of the windshield. Mine gets kind of plugged with bugs occasionally, and I vacuum it. I also change the cabin filter in the glove box more often than most people.
    RCO likes this.
  8. alanclarkeau
    7,045
    7,593
    I've not noticed it drip to the same extent as some of my older cars, but have still seen some - I had a drip tray under some in the garage which I would occasionally have to empty in humid weather.
  9. bisco
    52,193
    take it back and complain, did they do it for free?
    RCO likes this.
  10. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    First......you need to be sure that some "crap" hasn't accumulated inside the outside air intake and molded into a gooey mess.
    That intake usually is at the bottom of the windshield and you can see much of it with a flashlight.
    BUT......if this really is a brand new left-over 2016 vehicle, it is the dealers responsibility to FIX IT regardless of the cause.
    NOW would be a good time to call the "help" number in your warranty book........and maybe even check into the lemon laws where you live.
    The dealership likely will just screw around with you as long as you let them.
    pilotgrrl, Lucifer and RCO like this.
  11. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Mold is a health hazard, tell the dealer it needs removing or you'll die :rolleyes:
  12. Mendel Leisk
    41,752
    When you bought it had it been used as a demo for a protracted time? Was the smell there from day one, or gradually increased? How many miles on it now?
    RCO and kithmo like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Maybe it was a pizza delivery vehicle ?
  14. Mendel Leisk
    41,752
    Lots of anchovie pizzas? (n)
    Starship16 and kithmo like this.
  15. Prodigyplace
    12,619
    11,804
    Central Virginia
    Must have been @CoastRider 's previous vehicle :LOL:
  16. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    That was a burger van. ;)
  17. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    I thought he liked pizzas more :LOL:. He thought the wheel caps looked like pizza slices.
    One problem could be that the wires are made out of soy. A rat might have died in the vents, although I don't think there are wires in the vents. There have been plenty of these issues on PC.
    Starship16, bisco, pilotgrrl and 3 others like this.
  18. Sam Spade
    2,036
    1,023
    2017 Prius c
    Yes but not many in a car that new with a problem that severe.
    The "normal" problem usually occurs after a couple of summers and comes on gradually.
    ETP and RCO like this.
  19. Mendel Leisk
    41,752
    Maybe he's outa here? I'd like to know:
    1. How many miles on this "brand new" car"
    2. How much is the AC being run, pretty much constant?
    3. Is the car constantly being shut down immediately after running AC?
    #3 will leave standing moisture, in a warm/dark place, and it doesn't take that long for mold to develop in those conditions.
  20. 'LectroFuel
    880
    673
    One of those Fabreze clip ons could help in the time being. I just started using it this week since the new car smell is almost gone and it's noticeable, but not too strong.
    Starship16 and RCO like this.
